air compressor
Car: 88 Trans Am
Engine: 305 tpi
air compressor
i was wondering what everyone here was using for air compressors for their spray guns. brand, size, id just like to get an idea of what ill need and how much to pay.
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
60 gal cambell hausfield 7 hp 2cyl with 3/4" air lines
works great and for being a decent name brand it comes with a decent price tag... 750 CAD
ive seen the same size and types of compressers for up to $3000 i think the the IR Ingersol Rand compresser the same 60 gal and same airflow etc. was $2400 I had a Snap On 60 gal 3 cyl but I sold it when money got tight.
also if your buying a new compresser watch for duty cycles, airflow etc. buy for your needs
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Crafstman 25gal,4 hp,11yrs old.Not 1 problem ever!
I'd like to expand the question, who has a 120V one that'll work? or a paint gun that'll work with only the airflow that a 120V compressor can put out?
I don't have 240V in my garage, and a rental house so i'm outta luck...
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
My home one is a bitzer, Ingersoll Rand V twin pump, [circa 1963 when it was badged "Tecalmit"] and a 20 yr old 3HP Single Phase GEC motor.
The air receiver is about the size of a midget submarine.
A good test of a compressor is if it can run a DA Air Sander without the sander slowing down as the air runs down, most smaller ones cant cope.
But you can spray paint with almost anything, even a vacumn cleaner. My spraygun is Devilbiss, and i have an old no-name one for using with primer.
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Originally posted by Sonix
would that be a 120V version?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Its actually a generic ENCO brand.The cup is the limiting factor only 8 oz.
campbell and hausfeld/husky 60 gallon 7 hp or whatever.
I suggest getting a larger tank and 220, my buddy has the same air compressor pump as I do, but on a smaller tank. He has painted several cars with it, although he said the thing is always running. It now blows oil, but its also a good 10-15 years old.
Car: '86 Berlinetta
Craftsman Professional Series 60 gallon, 7hp. 220v.
I was going to get the same one from Husky, but the Craftsman one went on sale and was only 25 dollars more than the Husky...so I went with the Craftsman... I think at Sears the sale is still going on till the 15th of this month?
Mine yawns a lot. Only thing that really drains it is a DA sander. If you rent a home, I would consult the landlord about having a 220 outlet installed, then have your electrician make your power line from the compressor into a plug intead of straight line. Then you can plug it into the wall.
Car: 1982 Trans-Am
sellman, actually i'm not supposed to be doing any car work whatsoever, so that's why i'm not too keen on asking for 220V in the garage... (why would you want that they'd ask, and i'd say... uh....)
huh? they'd be putting an outlet into the wall, which sounds normal, then i'd plug in the compressor...?
or do most 220V compressors not have a plug on the end, it's just supposed to be wired in?
Car: '86 Berlinetta
Most 220 compressors (that I've seen atleast) have to be hard wired in. Typically to the fuse box.
I can understand your dillemma (sp?) now. The 25gal 4 horse one should work (maybe a bit slower, and with more water traps) for you. Plus I dont think it'll be as loud, so there's not a chance of you getting caught.
Your landlord sucks.
This is slightly off subject, but what would be the minimum required if you wanted to be able to do some DA sanding, and some minor painting... ie, just primer and or smaller objects?
Would a 2HP 33gal craftsman be enough?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by sellmanb
[B]Most 220 compressors (that I've seen atleast) have to be hard wired in. Typically to the fuse box.
Billy Decker
Sep 4, 2015 03:46 PM
