Wooshing sound in car at higher speeds.
Old Oct 10, 2005 | 12:22 AM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
When im at speeds above like 40 on my drivers side it sounds like i have my window partially open but its not, I looked the t-top over and it doesnt have any cracks or anything missing, is this sound normal for a 16 year old car, I am assuming it might be my t-top weather stripping, or a bad t-top somehow? has anyone else had this problem? thanks.
Old Oct 10, 2005 | 01:02 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Could also be that someone removed the plastic sheet inside the door. That thing blocks a lot more noise than most people think.
Old Oct 10, 2005 | 01:54 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
you know it's coming from your door?
my rear tires make some decent noise at high speeds (the last ones I had on there did anyways... The bald ones I put on it are pretty quiet... lol)
But in the rain or any sort of dampness, it don't matter what kind of tires... It's whooshin.
other than that, yeah, it's pretty normal to hear wind noise coming from the t-tops, and not much you can do about it if your weatherstripping seems ok.
you can peel the a-pillar trim off and adjust the slots for the t-top slides to sit a little lower, hopefully that'll seal it up a little more.
i need to the same on mine
Old Oct 10, 2005 | 03:33 AM
CrazyHawaiian's Avatar
Car: too many ...
Check the windshield, the door weather stripping, the plastic triangle right by the mirrors, and the t-top weather stripping. Check em all for leaks. Its probably wind from outside getting through a crack or leak somewhere. I use water to find leaks, either from a hose or from a pressure washer sprayer. Force it and if it leaks fix it.
Old Oct 10, 2005 | 03:42 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
if you smoke a good trick is to hold the ciggarette close to the glass and around the weatherstripping (dont touch or it may melt, and dont touch it to your tinted windows) and watch to see if the smoke gets blown around.
my wind noise was solved by rmoving the front plastic window runchannel (plastic triangle) cleaning it with some dishsoap and reinstalling it tight. it reinstalls easily.
sometimes having a friend drive and you look for windnoise is a good idea.
removing the dashpad may make it easier to locate windnoise.
a surefire way is to drive through a carwash. bring a towel.
Old Oct 11, 2005 | 12:39 PM
'87 IROC VERT's Avatar
Car: 2011 BMW X5 35d (diesel)
Engine: 3.5 ltr twin turbo diesel, 425lb/ft
Transmission: 6 speed auto
Axle/Gears: All wheel drive
If it's coming from under the hood, then check to see if someone installed a turbo when you weren't looking.....
Old Oct 11, 2005 | 03:12 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
The Turbo-Fairy!...no...wait...that sounds completely different...
Old Dec 7, 2005 | 10:14 AM
Dugan91rs's Avatar
Hi new 3rd Gen owner here. Mostly been a first gen guy.
Anyway, i get the same loud wind noise from my t tops, over 30mph. It appears that the drivers side t top, doesn't quite sit flush with the steel upper windshield frame, but where it locks down it appears flush. There is no actual wind coming into the drivers compartment.
I believe the t top sitting slightly higher than the windshield frame causes this. Is there any way to adjust this? It looks like the weatherstripping is too thick. I'm afraid to try and dead blow it down, i think it might hurt the lexan.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
