Flush door handle and round keys combo's
Old Oct 17, 2005 | 07:31 AM
Pete87TA's Avatar
Car: 87 T/A
Engine: Mini-Ram 383
Transmission: Built 700R4
I'm trying to find a set of flush door handles to use on my TA. I'd like to find a set that uses the same style key inorder to have it rekeyed to match the T-tops and hatch. Any ideas? I know the 9-'s turcks, but what else?
Old Oct 17, 2005 | 08:32 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
94 Grand Am
Old Oct 17, 2005 | 03:58 PM
Pete87TA's Avatar
Car: 87 T/A
More help....
Come on everyone...I know there has to be more out there. What are the chances of reusing my lock cylinders on a new set of handles?
Old Oct 17, 2005 | 05:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: More help....
Pretty good depending on if you want to put any effort into it.
A GM cylinder will fit into Intrepid handles with a little filing around the perimeter of the trim ring. Make a spacer sleeve and the retainer clip will hold it in. Even if it didn't fit, I don't have a boner for GM parts so, I wouldn't have cared to have a Dodge key for the locks. There were no keys with the handles though, so I made my GM cyls fit.
I think there are only two others plus myself with flush handles.
383 Firebird and Gecz28 are the ones I know of offhand... both of them used the same newer GM handles (though from different cars). IIrc 383 used handles from a Malibu... monte.. or... something along those lines...
Buick and a few other GM cars use the same as well.
Old Oct 17, 2005 | 09:44 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
I'm thinking of using the 90-94 or so chevy full size truck square flush handles. They did it in Hot rod one month and it was bad!!!
Old Oct 17, 2005 | 10:10 PM
deadbird's Avatar
Engine: TPI 305/ v6
If you have to use GM truck handles, use them off the s-10 - s-15 truck/blazers... same handle only a little smaller. Much better suited to the size of an f-body.
Just my opinoin though..
Old Oct 17, 2005 | 11:50 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
2005 Buick Century
My wife and I just bought a new 2005 Buick Century this year and it has flush door handles and the regular GM round key for the doors.
Old Oct 18, 2005 | 03:35 AM
Gecz28's Avatar
Car: 88 iroc vert
i had to get new keys cuz the hole is a bit small so i couldnt use the same cylinder.
Old Oct 19, 2005 | 11:02 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Re: 2005 Buick Century
Yeah, but the key is double-sided, right? That's the problem. My handles are from a Grand Prix and have oval "GM" keys... but they're the new style that are cut on both sides.
I'm just going to have the ignition/T-tops/hatch keyed the same and have separate keys for the doors.
Old Oct 20, 2005 | 11:32 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: Re: 2005 Buick Century
Your right they are double sided. I don't get to drive it enough to know I guess.
But I did notice that the Chevy Corsica also has flush handles. The handles on my TA are going to need replaced soon I may try them from a Corsica.
Old Oct 20, 2005 | 11:53 AM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I have been kicking this idea around too and Ive found that the mid 90s W bodies, grand prixs and regals, have flush mount handles and are rectangular instead of round which I think would look better than the round ones shown before. I also think they use a one sides key so you could probably have them coded to your existing key as well.
Old Oct 23, 2005 | 10:56 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Re: More help....
I have seen 383 Firebirds handles fist hand before his car was done. Jay the guy who did his car did a Great job, very clean!
Kevin
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
