How to add ground effects?
Old Oct 22, 2005 | 03:04 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I am wondering how you attach the flares that go along the rocker panels. I noticed on the car there was a support bar spot welded to the rocker itself and a horizontal support screwed to that. I removed the horizontal bar but was wondering how do I go about mounting this to the rocker itself. Anyone know what I mean?
Old Oct 22, 2005 | 09:57 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
I have no idea what you mean, but use duct tape. If you can't duct it fuct it.
Old Oct 23, 2005 | 05:31 PM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Engine: L31 Build in Progress
Transmission: NWC T5 till it blows
Doing it myself..
You need the piece welded to the rockers, use those and either tack weld or screw them to yours, and then install gfx
if you need pics, i may be able to go and get them to show you.
Mike
Old Oct 23, 2005 | 05:36 PM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Doing it myself..
Mike
Old Oct 23, 2005 | 07:41 PM
sixbanger's Avatar
How did you get that piece (the one spot-welded to the rocker)off the donor car?
Old Oct 23, 2005 | 09:52 PM
USMC3782's Avatar
Car: 86 TA, 00 Z28
How to
Depeding on tools you can try a sawzall or acetalyne torch.
looks a lot better when they are on thats for sure.
Old Oct 23, 2005 | 10:32 PM
sellmanb's Avatar
Car: '86 Berlinetta
I was actually coming to this forum to post the same question!
I am wondering if just a long piece of angle iron would work, and then just drill holes in the appropriate spots, and such? It would probably be stronger than the stock pieces.
Old Oct 24, 2005 | 08:16 AM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Your choice.
You can refab the pieces, but using the stock piece will allow easier use of factory mounting areas.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
