Help! locked keys in car!
Old Oct 25, 2005 | 06:55 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Well, I knew it was going to happen...I have locked my one and only set of keys inside my 1991 Trans Am, which has a dead battery. My buddy said he used to be able to just pry down the window where the t-top meets on his 84 z28, I tried that but to no avail. I'm out of ideas other than smashing a t-top.
Old Oct 25, 2005 | 07:07 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
pick the lock i dont know that sucks though man...
Old Oct 25, 2005 | 07:23 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Call a cab, the ones in my area carry slim jims and will open your car for a small fee.
Or call a locksmith, same thing
Old Oct 25, 2005 | 07:37 PM
navy02ws6's Avatar
The car's a project for right now, not running at parked at my work...so I have a couple of days before I'm going to see it again. The local junkyard sells t-tops for $30, which is probably a whole lot less than a locksmith would charge. But is it possible to switch the lock cylinder in a t-top? If not, I'd be SOL if I ever wanted to lock the new one...
Old Oct 25, 2005 | 08:01 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
the same thing happened to me 2 months ago. you are going to need either a angled rod or a coat hanger bent the same way. Slip it in between the ttop and window and attempt to push the little lever forward, or if you have power locks, use the end and mash the unlock button (if you can supply some power some how)..
good luck mand, i would hate to see you break some glass to get some keys.
Old Oct 25, 2005 | 08:37 PM
JB22's Avatar
If you have AAA, call em up. I locked the keys in one of my other cars, guy shows up and in like 2 minutes, hes in.
Its sick how easy it is to break into a car....
Old Oct 25, 2005 | 09:04 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
you could drill out the lock cylinder for the trunk.. after you drill it out you just turn a screw driver and the hatch pops.. had to do it with mine
Old Oct 25, 2005 | 09:11 PM
navy02ws6's Avatar
Hmm...I still think the t-top would be the best idea...anyone know if the tint level was the same for all years/models?
Old Oct 25, 2005 | 09:14 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I'm a slow learner, done it a coule times. Gently pry the windo away from the ttop. You should be able to get enough to where you can slide your hand in and pop a ttop loose. As long as the tops aren't locked.
Old Oct 25, 2005 | 09:30 PM
MNformula350's Avatar
2 Minutes, damn that's slow. I locked my keys in my 83 T/A years ago, and a friend who worked doing repo's opened the door inless then 15 seconds with a slim jim.
And yeah all you should need to do is take off the radio antenna, pry the window away from the t-top and pop the lock.
Old Oct 25, 2005 | 10:14 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
I would invest in a theif kit for this job and keep it for later, you will need it. I bought a kit from snap on that includes all needs for picking locks and a tool for sliding down the window. I have shaved door handles and one time left the keys in the car while running so I lost half a tank of gas before I could open it. Also, its a good idea to just keep a trunk key in your wallet for emergencies. I got locked out of my friends car in Chicago one time and happened to come across a homeless person who I payed to break into my car, no joke.
Old Oct 25, 2005 | 10:27 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
i did this about a month ago man....i just brought a long metal rod with me, pulled the window away from the car and stuck it in there and hit my rear hatch switch with the rod. then climbed in the back and hit the unlock button. really easy to break into our cars
Old Oct 25, 2005 | 10:29 PM
BlueZee28's Avatar
dont smash the t top you'll just get glass all over the interior...
Old Oct 26, 2005 | 05:44 AM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
slim jims are $1,using them takes 10seconds.
dont smash your ttop, thats just crazy.
try unlatching your ttop or something,once its unlatched you can just take it off.
Old Oct 26, 2005 | 08:44 PM
navy02ws6's Avatar
Yep, 30 seconds and a slim jim did it. Thanks for all your help guys.
Old Oct 26, 2005 | 10:18 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
slim jim.... **** dude. a ruler is all ya need. slide it in above the DRIVERS SIDE door lock and push down, you will here a click. ten seconds.....
i once used a folded up information brochure on cheveron credit cards when i locked them in the car at a gas station.....
attempted to make a video of it just now, can't work my sisters camera.
Old Oct 26, 2005 | 11:14 PM
BlueZee28's Avatar
glad you didnt' have to break any glass
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Kaweh
Aug 9, 2015 02:54 PM
