hawks notchback ???
Old Nov 8, 2005 | 08:50 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
hawks notchback ???
I'm thinking about getting the hawks notchback. Has anyone used this? How does it look from the outside? How does it look inside the car ? Any Body Alingnment problems ? Any input would be great .
Old Nov 8, 2005 | 06:37 PM
KissThis's Avatar
Car: 1984 Firebird V6
Ooooh I wish I knew who it was, I totally forget. BUT there is a board member that has a Notchback.
I'll look and see who it is who had it.
Edit:
Ok I found it
GTA4ME
There's a link to his website on his sig, He's got a post in the Knight Rider replica thread too.
Old Nov 8, 2005 | 11:24 PM
JT's Avatar
JT
Community Administrator
Edit:
Ok I found it
GTA4ME
There are other, original, Notchback owners here, including myself.
i also have a small webpage for them.
Old Nov 9, 2005 | 04:47 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
those notch backs are cool,i bet they weigh alot less too.
and are cooler in the summer.
Old Nov 9, 2005 | 05:00 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
does the back window roll down i.e. Honda Del Sol?
Old Nov 9, 2005 | 05:37 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
On an original factory notchback the rear window is tempered glass with an integral heater element wire. From what I understand the rear window on these aftermarket notchbacks is acrylic. In both cases the back window is fixed. I have an original notchback hatch that I plan to install on my Firebird Formula. I'm toying with the idea of making it removeable as in the Chevrolet Avalanche.
Lon
Old Nov 11, 2005 | 08:19 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I plan on making mine detachable too! I have to pull it off to fix a water leak anyway, so I figured I would try it. I probably won't get to it until the spring, but I will post picks when I get it done. If anyone else does it first, let me know.
Old Dec 17, 2007 | 08:25 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: hawks notchback ???
Has no one bought one of these? I can't seem to find anything in the searches I made.
Old Dec 17, 2007 | 09:22 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
I bought one from Hawks, excellent craftmanship! The new notchback is about 45 pounds and yes the glass is actually acrylic which is even lighter than actual glass. It is fixed by a rubber seal and the acrylic may need some very minor work on some edges to get it fit right. The rear original latch did need some work since in my case I needed to rotate it 180 degrees of the original position and make new holes on the steel original pull down bracket that is reused to make it work right. I also needed to exchange the gas lifts with a friend of mine since the ones that I had where to "new" for the more lighter notchbatch and when it opened it tend to do it to hard, my friend's gas lifts where older and provided a better more controlable lift. From 1 to 10 I give it a 9. From all the cutting and chopping and deleting that I have done to my car to make it lighter this was the most rewarding and in my opinion is way better looking than the original glass.
For a picture of the notchback please see the thread "Finally" on the power adder forum, since the site wont let me upload the picture again for you to see.
PS: The hatch does not include the aero spoiler that you see in the picture
Linson
Oct 24, 2025 02:00 PM
Veaceonee
Sep 29, 2016 08:15 PM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Blkdth87
Sep 16, 2015 01:40 PM
