Glass vs. Plastic T-Tops
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Is one better than the other as far as quality or anything? I have plastic now, wondering if going to glass would be an upgrade?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The lexan (plastic) is about 1/3 the weight I'd guess, but they crack and look bad. I switched to glass since they don't get those nasty spiderwebs. Basically they're the same thing- a roof.
Car: 92 Z28
Engine: Boosted LSX
the plastic ones crack(spider looking cracks)
The glass ones scratch
The plastic is lighter
The Glass is heavier.
weigh your options. If nothing is wrong with yours don't bother swapping.
Engine: LT1; None
lol, ok, sounds pretty straightforward. Mine have some of that spiderwebbing...doesn't bother me that much so I guess I'll just leave them be.
Engine: 4++,350 & 305 CIs
the plastic 1s pop out easier at elevated speeds
I run plastic for the quarter mile and glass for daily driving/ top speed runs
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you can wet sand and buff the plastic ones and make them look like brand new. I was going to buy new ones, but while I was wet sanding and buffing the car I thought why not wet sand and buff the t-topps. It works on my plastic taillights. Came out better than I could have wished for. No more new tops for me!!
Car: 86 T/A
Engine: HSR 355
A fair amount of the Lexan ones I've seen are actualyl spiderwebbed through the whole sheet, not just surface scratches.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If I wanted to paint a set of tops, would I be better off painting the lexan ones?
I've got an extra set of each, and I want to get that hard top look for the car.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
hey, now that would be pretty neat.
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Id be worried about the flex in the lexan to mess up the paint. I could be wrong tho.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I second that one.
Paint it with bumper black, after all how often do people sit in their T-top and look up and go "Waow the sky is so blue today when I look through my T-top Lexan waow"
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by TPl383
someone painted their t tops already.
https://www.thirdgen.org/techbb2/sho...ighlight=paint
Engine: 350 tpi
if possible I would try to contact firbird and see what he used on the tops, It has been two almost two years and any problems would have allready come up.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
