Quick door question.
Old Nov 15, 2005 | 04:51 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I'm sure its been asked before, and i know most of the parts are the same, but are 3rd gen Camaro doors, exactly the same as 3rd gen Firebird doors?
If they are it gives me a better chance of locating a good second hand passenger door.
Old Nov 15, 2005 | 09:05 AM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
there will be minor diferences such as the ground effects and door molding, but you can definetely use one
Old Nov 15, 2005 | 12:59 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Are there holes pre drilled in the door for the ground effects btw?
Old Nov 16, 2005 | 01:59 PM
Car: 85 TA
if the door had ground effects on iit the wholes will be there
the holes might not work for you though if the door is off a car with different ground effects
not a problem though, just make a template off your old door for where the holes need to be on the new door
I have to do this same thing with one my doors
Old Nov 16, 2005 | 02:51 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Thanks again, unfortunately mines got nothing at all on the outside of the door, so i could do with finding "un-holey" ones.
Old Nov 16, 2005 | 10:49 PM
Car: 85 TA
if you do find one that has ground effects make sure you pull the ground effect piece off the door.....they like to rust there.....if it is good you have to have the holes welded in since yours doesnt have a piece there
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
TheExaminer
Sep 6, 2015 11:40 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Ian Irvine
Sep 4, 2015 08:08 AM
