steering wheel
Old Nov 20, 2005 | 08:27 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
steering wheel
Will a 82-86 trans am steering wheel work on my 91 firebird that originaly had a steering wheel with an airbag?
Old Nov 24, 2005 | 11:33 AM
snapsmagee2000's Avatar
Car: 91 z28 100kmiles
Transmission: 700r4 hoping to be t-5 soon
Axle/Gears: 3.42 posi
nope it requirs two different horn wires to plug them up
plus ur airbag light will always stay on
Old Nov 24, 2005 | 03:06 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It *will* work. Its a direct swap. I have a friend with a '85 Firebird steering wheel on his '91 Trans Am. Just remove the air bag idiot light bulb from the gage cluster.
Old Nov 24, 2005 | 09:23 PM
MNformula350's Avatar
Yes, I put a 87 Firebird 3 spoke steering wheel in my 90 Formula which originally had an airbag.
and as far as the 2 horn wires go, yes there are, but the split off of 1 wire so can be cut down on the single part and wired as normal.
Old Nov 26, 2005 | 10:15 PM
87transkid's Avatar
Car: 88 Formula
Engine: 350 TPI / supercharged
Transmission: 5spd manual / dual friction centerforce clutch 373 rear end
you can do it. its easy but um be care full with your air bag a 3volt refrance will set it off and thats not pretty so once again be carefull
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
