Gas Tank Recall...Read if you have a 1991 Camaro RS.....
#151
Re: Gas Tank Recall...Read if you have a 1991 Camaro RS.....
Unless the 1LE tank is NOS in some random dealership hanging out... But they do replace with aftermarket if there is a leak. If you smell gas and you in the vin range and with that low mileage I can say with 100% it will only get worse as the filler neck cracks with age (more miles). You can have pressure in he tank and still have a small leak.
#152
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
I recently purchased a 1991 B4C Camaro with 13k original miles; it falls right into the affected VIN range.
When I fill it up to max capacity (meaning there's probably some fuel in the filler neck), I noticed a faint smell of gas. It goes away after some brief driving and doesn't come back until I top it off at a gas station, so I never thought much of it until I read this thread. When I unscrew the gas cap, there's good fuel pressure and the sound of it being released, so if there are leaks they can't be big.
Is there any way I can visually check the leaks before bringing it to the dealership?
Our dealership is decent so I'll give them a note and see what they say. I'll be sure to include the full recall information/language. A print-out from the NHTSA wouldn't hurt. I'll update on what comes from it.
If it needs a replacement, does anybody know if you can still get a 1LE baffled fuel tank?
Bear in mind a smell isnt a cause for alarm on the tank. There are a number of seals and vents that have aged since it was new
Dont worry too hard on the 1LE baffled tank. All 90-92 cars used the same baffled tank (search the history forum)
#153
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I have a 91 Z28 and lately my gas tank has been releasing pressure randomly. Today when I was putting some interior back in my car it made a little belch that sounded like the gas tank let go of pressure. So I took the gas cap off and put it back on to make sure it was on good.
Then I went driving later in the day and it did it again while going at low speeds over a speed bump. I'm thinking this recall may be to blame. Will dealers still inspect and fix this for free? Or could it be a faulty gas cap?
How do I know if my vin falls into this category? And no, I can't smell any gas as far as I can tell. At least I couldn't tonight when I got down by the wheel well and smelled.
#154
Well, sure enough I talked to them and they played dumb. I sent them a physical link to the NHTSA recall, the numbers, and the other information. Their response was that they couldn't find anything in the system, so I have to call GM. It's a little surprising because it's a decent dealership and I bought my wife's car from them, so we'll see... I'll do the check myself and see if I even need it. The more I drive my car, the better it gets as it wakes up from hibernation, so the hint of fuel smell is no longer showing up after refills.
#155
Car: 1991 Z28
I tried to check mine yesterday and I could only see the top of it through the little hole in the wheel well. I didn't feel or see anything wet....so I might try a new gas cap before I commit to calling the dealership.
#156
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
Did the 91 Firebird have this recall, because i filled my tank up ($44) and got back to my house and notice it was leaking, it leaked for 2 hrs, until i had about half a tank left and then it stopped... I plan on doing some JB weld until i can get the money to get a diffrent one.
#157
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
just attempted to find info on my 2 current Z28's my 91 Z #L130952 and my 92 #L162827
both are in the recall numbers and both the dealer and gm service said they can't find anything. My 92 will spill gas on a hard turn if the tank is full. and the 1991 has the paint eaten around the tank opening.
I don't think its because my cars are not effected, they just dont know where to find the information anymore. Need to figure something out and have these 2 cars fixed.
#158
Car: 91 Z28
Just called the dealer and all I had to do was give the last 8 digits of my VIN. The guy on the phone found the recall immediately and I'm scheduled to bring it in on monday to get it fixed.
#159
Car: 1991 Camaro RS
Engine: 5.0
#160
Car: 1991 Camaro rs
Engine: 305 TBI
Transmission: WCT5 Rebuilt by Astro
Axle/Gears: Borg Warner posi disc 3.27
Re: Gas Tank Recall
Recently went through this with my 91RS. Had to go through three dealers to find one willing to assist. There are no OEM tanks in stock (so I was told) however I located one at Classic Ind., which was ordered by the dealer and I picked it up. I already had the tank dropped due to fuel pump issues, so I took them my leaking tank and they gave me the new one..
You can get this accomplished, just be patient and find a service manager who is willing to do a little work..
#161
Car: 1991 Camaro rs
Engine: 305 TBI
Yes, they will! I used the logic that I was saving them money, as I had the tank already out, took a couple of days to clear it thru zone manager but got it done.
New baffled tank....
#162
Car: 1991 Camaro rs
Engine: 305 TBI
Read original post! I was able to just exchange tanks, but I had a fuel pump problem and already had everything dropped. Service manager cleared it with district manager. All I had to do was show pictures of torn down car.
#163
Car: 1991 Camaro rs
Engine: 305 TBI
Mine wasn't running as I had dropped tank due to fuel pump failure. Took cell phone pics of torn down car. They ordered new tank and I swapped old for new when it came in!
#164
Car: 1991 Chevrolet Camaro RS
Engine: 305 lo3
Does anyone know if this is still being honored? I just read the post today and am wondering if it is worth my time to even bother calling up the local Chevrolet.
#165
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
I'm wondering this too.
#166
Car: 1991 Camaro rs
Engine: 305 TBI
Depending on dealer ship, be prepared to go directly to the service manager. Believe me some will act DUMB, but stand your ground and you will get your issue resolved!
#167
Engine: 305 lo3
They told me at the local dealer that nothing came up at all using my vin. Should I just attempt another dealership in another town because they have nothing at all on file for my vin.
#168
Car: 1991 Camaro rs
Engine: 305 TBI
Try another dealer and don't talk to service men, get directly to service manager.
#169
Car: 1991 Camaro rs
Engine: 305 TBI
Go to message boards. Then go to body. Click on it and you will see my post about gas tanks. Click on it and there is a comprehensive article on what you need to do. Stick with it. You can get it done!
#170
Car: 1991 Camaro rs
Engine: 305 TBI
#171
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Really glad i saw this thread, i have noticed since i bought my car two years ago every now and again i catch a wiff of raw fuel and it then i noticed it was mainly on fill ups or the day after in the heat so im guessing there is a pin hole leak that vapors are escaping from. Really helpful thread guys thanks for keeping it alive, i plan on calling the Dealership today to discuss this with them.
#172
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Mine Cannot be leaking since I Loose a Few Pounds of Pressure in the tank when i fill up everytime
#173
Car: 1991 Camaro RS
Can i still use this recall? My car reeks of gas when you start it(the oxygen censor is broken i don't know if that's why) I'll have to check the gas tank but could i still have this done?
#174
As long as your car falls within the vin range is has a leaking filler neck and wasn't wreck to cause tank damage they cannnot by federal law say no. Most service mangers will try to tell you that since the car is over 10 years that your screwed. But really the law says only if the recall came out before the car turned 10 (not sure if this is model year or manfacture date on door) then it's the manfactures duty to fix it and if over 10 when recall came out it's the owners responsibility. So with that all third gens with this recall call are good for life because this recall came out before any of the cars on the recall list turned 10.
You will need to provide the recall info that's attached to this thread to the service manager. Most will not be able to see the recall by you vin since the car is over 10. But all service mangers can look this up by campaign number or by simply going to www.safercar.gov. Do not let them pass you away with them saying the car was fixed years ago, even if it was and now has the exact same problem as in the recall they have to fix it again. Good idea would be to replace the in tank pump if original to the car while the tank is off. Also FYI the fuel pump seal is covered by the warrenty. So the only charge would be installing the new pump on the fuel pump assembly that goes into the tank and the cost of the pump.
Again this recall is good for life so take avantage of it
#175
Car: 1992 Camaro RS
Engine: 305 TBI L03
yeah mine smells like a gas station too :/
#176
i have question so even to this day if this problem is accoring i can go and get this done still ? Or would i have pay out my pocket because my car smells really really bad of gas to the point of a head ach
#177
On your question See attached on all the details about how to get your tank fixed and if it falls in the vin range and year range as per the PDF file. Note Dealerships can look this recall up buy Dealer Product Campaing Bulletin # 92C36. Or by just Campaing # 92C36. I've found one dealer calls it just Campaing number and doesn't know what Dealer Product Campaing Bulletin is... But this is the only way they can find this recall in their system. I recommend you print the PDF and have it handy when you bring the car in. Without mine it was like talking to a brick wall.
They can not charge you anything they even have to provide a longer car. They might try to stick you with a new seal for the fuel pump but they shouldn't as per the recall it was included in the cost and was to replaced along with the gas tank.
1. You must have the OE tank from GM that they installed or was replaced years ago but was a GM tank.
2. Your car must not have been in a wreck that would have damaged the fuel tank. In other words if the side of your car was hit with the filler neck and cause physical damage then it would be voided. I suggest tanking pictures of your car before you bring it to the dealer so that they can't claim that it was in a wreck that cause damaged to the tank.
That's basically it, they won't be able to look your car up by vin nether will customer service because of age and they purge that info after a certain date. Don't let them tell you that well when I type the vin nothing comes up so you don't have any recalls. That is just a standard I don't want to lift a finger an do my job kind of quote. The other quote you might get is them saying it has been already repaired. That doesn't matter because if the same leak happens again then they have to repair it again and can't charge you. In fact my car has had three gas tanks all from the dealer for free. First one was with the first owner and second tank was with the second owner (my brother) and third was with me.
Another quote they will say is that it's over ten years old. The law reads that if the car was less then ten years old when the recall came out then there is no time limit on getting it replaced for free.
Tho if the car was over ten years old when the recall came out then it's up to the owner to have it fixed.
Have any question shoot back I have this thread on auto alert send to my e-mail so I should respond quickly.
#178
Thanks so much for clearing that up because i recently brought my 91 camaro it never been in accident and it smells really bad.
#179
Just got back from Starling Chevy in Deland, FL. Pulled up to the service dept, told them I didn't think the recall work was ever done. They punched in my VIN and pulled the info, ordered a new tank on the spot. I didn't have to do a dang thing, and here I had printed all the NHSTA info on the recall and brought it with, turned out it wasn't needed. Hell they didn't even look at the car other than to get the VIN. They must need work or something, LOL.
SWEET.
SWEET.
#180
Car: 1991 Camaro RS
you gotta be shi**in me... i gotta see a pic of the new tank..... haha For real. I want to change my Fuel pump and I was thinking of having the dealer get a new tank, and I'd buy a New pump for them to Replace while they were there.......... of course I wouldnt say anything till they ordered the tank, and id say BTW I bought a pump...
#181
Car: 1986 Trans am
Engine: tuned port 305 LB9
Axle/Gears: .323
So they do have to give me a new tank right?? the dude kept sayin that he would have to patch it or some bull crap.
#182
They have to give you a new tank trying to weld or 're solder on a used tank is just asking for an explosion. Under federal law they have to replace it patch is a quick fix that will only leak down the road. Has to be a new tank per the recall accept nothing else.
#183
Car: 1986 Trans am
Axle/Gears: .323
OK so I finally got him to order me a new tank, he said it'd be here in a week. Do they also replace the pump and sending unit??
#184
The only thing related to the fuel pump and sending unit they replace is the gasket housing. It would be wise to give them a new pump or have a new one installed. They will only charge 30min to install the new pump in the assembly pump and sending unit. If they try to charge you the full amount in labor as if they were dropping the tank tell them to **** off. They can't double dip on labor chargers if they are already getting paid for the same job from Chevy. If you do replace the pump or if not either way change the pump sock.
#185
Car: 1991 Camaro RS
Some people might say airtex is fine. its the installer. HA. Do yourself a favor and look up Airxtex fuel pump reviews on google or your parts stores website!
#186
Engine: 4++,350 & 305 CIs
I'd almost bet GM wont put a aftermarket pump in the new tank unless they are veeeery cool.. Here is a great pump to use.
http://www.racetronix.biz/customkiti...=FPA%2D019&eq=
#188
Car: 1986 Trans am
Axle/Gears: .323
I got a new fuel pump for it today and they finally called and they have my tank at the shop. Its been a month haha. But tomorrow my baby will have a new gas tank!!!!
#189
What did you guys do that had dealerships refuse to do the recall because the tank was discontinued through GM? The local dealer says they cant help me. Do they need to submit paperwork to GM or something to buy an aftermarket tank?
#190
I just got off the phone with GM. 45 minutes later and they cannot even find the recall in their system. I gave them my VIN and the bulletin number and they told me that nothing comes up on their end!!! Now I'm frustrated. They said they would call me back! Those of you that had this done already through a dealership, can you please send me the dealers contact info so I can call them and see what they did to have GM authorize this recall? If you had it done over 4 years ago then just remember that the dealership may not even remember it so ;Im hoping some of you guys that had it done within the year can help.
#191
Pm your email me if you still have issues and I'll send you a copy of my receipt.
Meanwhile here is the DM over the gas tank recall.
David
1-800-222-1020
X11361
#192
These dipshits at GM are beginning to get me pissed. They just called me back and told me I am **** out of luck with this recall because my VIN doesn't have any open recalls! They said there is nothing they can do and have no more advice for me. My vin is 1G1FP23F2ML188440. 1991
Model year.
If anyone with any paperwork who has had this done can help me out with either contact info or paperwork then can you please email me at bottledz28@aol dot com.
I called the number listed above and they will not transfer me to that extension unless I have a case number! I argue with lady and them she wants my phone number AND home address!!! WHY
Model year.
#193
SWEET.
SWEET.
#194
Model year.
Model year.
#195
Model year.
Model year.
1-866-790-5600
#196
However, GM no longer makes or stocks our tanks. SO! I called GM and had them run my VIN for recalls... this one came up of course. I let them know the dealer I was working with. Took them some time (over a month) but the finally came through with an aftermarket tank.
After the decided to go aftermarket with the tank, they suggested using an actual GM dealer and not an independent. Apparently independent dealers do not have to perform the work, and some will refuse. So, I would ask GM what dealer I should go to if I were in your shoes.
GM will work with you as long as your car is actually part of the recall. Some VINs were not included, and these will be trouble.
#197
I just went to the dealer to start with. But first, I verified my VIN was within the recal range, printed the recall letter, etc. I had all the documentaion I could find before I went. Turned out I didn't need it. The service dept at Starling has been awesome.
On to the independent dealers refusing they are breaking their contract agreements with GM and Federal Law. Since they represent the company they have to repair fix and do recalls on GM products. I've had issues where GM dealers refuse but I file complaints with DOT and GM and so far to date one dealership was fined for refusing to perform the work.
But on the tanks yes the tanks have been long gone, the only two manfactures I know of for this car is Dorman (only seen this at Classic Industries) the other is Spectra.
#198
Actually every vin within the rage was effected and part of the recall. It stated every car within the range had to be inspected. So I image they had the problem with the entire batch of tanks. Same thing happen with the seat belt recall they first started out with just a few vins and then expanded to have every car within the range part of the recall. Main problem is with GM is that if it was checked years ago or fixed once before it was removed from the system or they purged the vins after so many years. They GM didn't keep accurate records per Federal Law because recalls are good for life and have to be repaired even if they fixed it once years ago for the same problem. I know because my car has had a few tanks installed and is about to have another tank because it has started to leak at the same point as described in the recall. (FYI all my tanks have been aftermarket except the first two). Most of the third gens didn't probably have any issues when they were younger but most if not all will have this problem as they age. The problem is that they didn't have any ability to have the filler necks to flex and they didn't solder them correctly. With those two combine you will develop leaks at some point.
Yes, contractually independent dealers are supposed to, and such and such. But, unless a stubborn independent is your only option, why fight it? A lot easier to go to a dealer who is happy to take the work. They get paid by GM, so the smart ones do it gladly.
They got my tank from 1AAuto. Not sure what brand it is, 1ATony would know of course.
#200
As far as the VIN, yes you are correct. This is what I meant when I said 'not included'. Meaning, not in the VIN range. Yeah they asked me why the recall work hadn't been done to my car. How the heck should I know? LOL. I'm not the original owner, LOL. But, good chance it failed AFTER it was brought in for testing.
