Headlight switch question
Old Dec 13, 2005 | 11:17 AM
89MOCROC's Avatar
Car: 1989 RS
Engine: 2.8 V-6 (for now)
Transmission: 700 R4
Last night my headlight switch appears to have broken a bracket of some sort when turning my lights off. My car is an 89 RS and the switch is pull out **** located on the pod to the left of the steering wheel. The switch will not push all the way in so the parking lights remain on. Has anyone here dealt with this issue? The Haynes manual was not much help on this one (Maybe I'll find the service repair manual in my X-mas stocking) I'm going to the "Auto Recycling Center" (call it a junkyard and they will kick you out) tomorrow morning. Any advice anyone has for me on this repair would be much appreciated.
Old Dec 13, 2005 | 06:19 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
most likely the switch broke... and they aren't fun to replace
Old Dec 14, 2005 | 07:21 PM
my82roc's Avatar
Car: 89 Iroc Convertible
The exact same thing happened to me in my 82 camaro.I would push in the headlight lever and the whole switch would move inside the dash.I could only get the headlights to turn off but the parking lights were still on.There is a screw that holds the switch mounted in place and it had fell out leaving the switch unsecured inside.
Old Dec 14, 2005 | 07:28 PM
my82roc's Avatar
Re: Headlight switch question
Originally posted by 89MOCROC
I'm going to the "Auto Recycling Center" (call it a junkyard and they will kick you out) tomorrow morning. Any advice anyone has for me on this repair would be much appreciated. [/B]
BTW I noticed you are in the Philadelphia area.What auto recycling center (junkyard) do you go to?
Old Dec 14, 2005 | 09:51 PM
89MOCROC's Avatar
Car: 1989 RS
Rossi's on 202 in King of Prussia. They have 4-5 3rd Gens. Most of them are picked pretty bare but they did get a new Z-28 in in the first half of the year.
Old Dec 14, 2005 | 09:56 PM
89MOCROC's Avatar
Car: 1989 RS
So the switch does not need to be replaced? Only the screw that holds the swith in the bracket?
Old Dec 15, 2005 | 07:39 AM
my82roc's Avatar
Are they a u pull it type of yard?I usually go to shortys in conshohocken.They usually have a few 3rd gens too.To check the headlight switch first remove the bezel and then move the lever in and out just to make sure it works before getting a replacement.My mechanic fixed mine while it was in the shop and he told me it was secured by a screw and i havent had a problem with it ever since
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
