firebird gauges
Old Dec 16, 2005 | 04:47 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
firebird gauges
im looking for more info on puting after market gauges in a firebird. ive seen time and time agian gauges in camaros, but what about firebirds? i havent seen much....
Old Dec 17, 2005 | 09:36 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
where is everyone?
Old Dec 17, 2005 | 02:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I only have an apillar pod with water temp and oil pressure.
I think it was Karps TA that replaced every guage with an aftermarket autometer and cut out the right two pods to fit four of the smaller 2 1/16" guages. He put a black filler panel around them. While I think he did a good job, I just couldn't stand that look. I had thought about just replacing my speedo and tach with matching carbon fiber ultralight series guages but I'll probably just end up swapping in a 4thgen dash.
Old Dec 17, 2005 | 03:48 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
It can be done. Just need to be creative. I got tired of my old design and have started a new panel. Should have pics of it in a week or so, just waiting on some things to come in.
Old Dec 17, 2005 | 07:01 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If yours blended into the stock dash (texture/colorwise) I would've copied it immediately. That was my only qualm.
Old Dec 18, 2005 | 02:16 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
yeah i was defenatly thinking to go with the in-dash 5" tach and speedo, but as for the others, i didnt know what layout i liked better...
...and like iansane stated, it would be cool if the layout/style kinda mimiced the stock style. like maybe red-backlite gauges?!? that'd be cool.
what about wiring.... mines a 92, so would i have to rewire everything? or ya think i can get away with using the stock wiring, and sending units?
what do you guys think of that new 4 in 1 5" gauge autometer just came out with?!?
Old Dec 18, 2005 | 02:28 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Those would be great. If they matched the style of the birds. I think the carbon fibre ultra lite's were the only ones that were somewhat similar to took crosshatch pattern.
Old Dec 18, 2005 | 09:02 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Well matching the grain of the plastic is going to be near impossible. You'd either need to make a mold and fiberglass the whole section, or smooth out all the grain and then paint the piece to make it look like all just one piece.
Old Dec 18, 2005 | 12:55 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
See, I think I'm just that much of an **** perfectionist. If I can't do it so it blends it and looks good I don't even want to finish it.
Maybe I shouldn't own a thirdgen.
Old Dec 21, 2005 | 06:54 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Trust me I'm a perfectionist. However the stock gauges did not fit my needs either.
Here's a peek at the new idea. And it's real carbon fiber not just a decal lol
Old Dec 21, 2005 | 07:43 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Karp, how much do you want to charge to make me one of those setups in the spring?
Old Dec 22, 2005 | 12:03 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Just not my thing I guess. To me there is just too much contrast between the carbon weave and stock guages bezel texture. Looks out of place to me.
Would there be enough room to set all the guages back an inch or so and make a large clear bezel to go over everything? Kind of like 4thgens?
Old Dec 22, 2005 | 07:30 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Probably if thats what your after. I don't like the stock look. If I wanted that I would have just got the inlays and covered the stock gauges. That would have been about $600 cheaper and a helluva lot easier. lol
The top of my console as well as the radio plate is also being done in CF, so the look will blend in throughout.
Again I'm just showing that it can be done, but you need to be creative and willing to get your hands dirty.
Old Dec 22, 2005 | 07:39 AM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
Karp, are those 5" guages in there
Old Dec 22, 2005 | 11:25 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Karp that looks pretty good... if I did that I think I'd just put a plain smooth panel in the rear where you have CF and then sand the grain smooth on the rest of the OEM panel... the paint it all black with silver gages like you have... that would look sweet!
*How hard was the wiring??
Old Dec 23, 2005 | 07:34 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
That was my original thought. However it then means you have to sand everything else on the dash smooth. Which didn't appeal to me.
And that isn't finished. It's like I said a sneak peek. It's mostly just mocked up at this point.
Gauges are 5" and 2 1/16"
Old Dec 23, 2005 | 12:51 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
karps, i think it looks good. very similar to what i had in mind. but is there a piece of plastic sheet that mimics the same texture of our dash in place of the carbon fiber?
Old Dec 26, 2005 | 01:11 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Not that I can find.
Other option is sanding the whole damn thing smooth.
Old Dec 26, 2005 | 01:30 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
i like that.
problem would be is id have to sand all the dash panels and paint all of them. hopfully it wouldnt look like some teenagers' honda! haha
where did you get the plastic to put in place of the 4 holes?
does that one piece support the gauges? or do you hae some sort of support behind it?
Old Dec 26, 2005 | 01:56 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
That is HOT!!!!
Old Dec 27, 2005 | 03:17 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Some finished pics. Sorry for the poor quality.
Old Dec 27, 2005 | 03:19 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yeah, definately sweet! How much you got in it?? $500? What is the gage backplate made out of?
Old Dec 27, 2005 | 03:21 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Now that looks a million times better. Blends in perfectly and can hardly see the separation line. Good job. That guage setup was really the only thing about your car I didn't like.
Old Dec 27, 2005 | 03:24 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The gauges themselves were probably around $500 so yeah somewhere around that. I filled in the original holes with ABS plastic that was about the same thickness. Then epoxyed behind that a thicker sheet of ABS. The panel itself is pretty stout.
Old Dec 27, 2005 | 03:28 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Sounds cool. Any more pics of your car??
Old Dec 27, 2005 | 04:11 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Sure.
more here http://home.wi.rr.com/karpsta/Trans%20Am%20Pics/
Old Dec 27, 2005 | 05:58 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
This is probably a useless post... but..
I am in process of designing custom overlays that light up red. I can't disclose anymore, but I guarantee they will kick ***!
Look for me posting here with the final product in few weeks.
Laters.
P.S> As of now I have the indiglo white faced gauges and I don't like them.
Old Dec 28, 2005 | 09:16 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Looks just the way I did mine. I like it
Old Dec 28, 2005 | 10:06 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
you guys wanna share with me what marterials you used?!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
ChevyZ71
Aug 13, 2015 07:30 AM
