vacumm storage tanks
Old Dec 16, 2005 | 08:09 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
does anybody know that if you take the two storage vacumm tanks off the car that are located under the car behind the headlights, what that will do, and what do they supply vacumm to
Old Dec 16, 2005 | 09:07 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I only have (had) one and it made sure the AC had enough pressure to open/close the flaps.
Kevin D.
Old Dec 16, 2005 | 09:33 PM
Car: 87 trans am
i have two on my car, one right below the battery, and one right below where the stock air box was, so they are only for your a/c
Old Dec 17, 2005 | 04:18 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Its just reserve vacuum for the dash air vent control doors. At near and wide open throttle there is no vacuum so all the dash control vents would temporally default to Defrost Mode until vacuum came back.
If you've ever driven an old car from the 1950's you'll notice that the vacuum powered windshield wipers stop when you are accelerating or going up a hill.
Bohemian
Aug 15, 2017 05:11 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
