Hood mounting question
Old Dec 20, 2005 | 12:00 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I've been running a fiberglass hood for about two or three months now. I've got nothing major to report, everything installed/lined up fine and I bought the fiberglass hood struts from GM at the cost of a kidney. The hood is very solid and stays where it is supposed to, but the back end (closest to the windshield) moves up and down some. It only moves about a 1/4 inch and only does it on the driver’s side. The passenger’s side stays put. It also makes a very annoying squeaking sound. I already tried raising the bump stop on the hinge to take out some play and it didn’t seem to help. I can’t crank it up any higher or the hood will come out of alignment.
When I installed the hood I removed the rubber v shaped things on the top of the fenders because the hood wouldn’t close with them installed. Should I put them back and figure out how to get them to work? How can I hold the rear of the hood down? The squeaking is bothering me like no other.
Also, probably not related but I will throw it out there just in case: the hood latch sticks some but it did that before with the steel hood.
I wouldn't mind running pins if it wasn't for the fact that I already purchased the fiberglass hood struts.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
