hood pin issues
Old Dec 27, 2005 | 10:33 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
hood pin issues
im putting hood pins in and i drilled the holes in the core support next to where the rubber stops are. but when i shut the hood it doesnt stick out far enough because the core support is boxed. has anyone had this problem? and what did you do to fix it
Old Dec 28, 2005 | 09:13 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
why are you puttin hood pins? do you need them?
Old Dec 29, 2005 | 12:03 AM
muteboy49's Avatar
Car: 84 Camaro
my latch is messed up and its a pain in the *** to open so some hood pins in the front seemed like a good idea, my hood is shot neways
Old Dec 30, 2005 | 08:21 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I dunno what kinda hood pins you have. But i have the Mr Gaskets ones. They're double nutted. One nut goes down below the core support, the other one on top. I remember in the core support there were holes in them about 1 1/2" in diameter. I stuck my finger in the hole,balanced the nut on my finger and started turning the rod part till it started threading. Definate pain,but do able. Hope this helps a little
Old Jan 2, 2006 | 12:27 PM
Irocman86's Avatar
i did the same thing it wasnt to difficult to install em just time consuming
Old Jan 3, 2006 | 10:06 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
one reason i think i need pins is: i have a fiberglass hood and when i'm going over 80mph, the corners of the hood start lifting up due to the air being pushed up from the headlights....either hood pins or headlight covers would make the car more aero!
Old Jan 3, 2006 | 03:43 PM
Demon355's Avatar
I'm getting a latch on pin kit. 4 corners for each pin. The hood I'm getting is the Harwood 2"-3" cowl.
Old Jan 3, 2006 | 04:44 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
i had the same problem with the double nut pin. I didn't like the hole in the raidator support as a good position for the pins so i cut a whole in the radiator support and used that hole to hold that bottom nut. It resulted in a nicely placed pin and still a structurally secure radiator support.
Old Jan 3, 2006 | 08:31 PM
Irocman86's Avatar
hood pins
here is a pic of my car its missing the scuffs and the hair pins but it does surve justics
Old Jan 3, 2006 | 10:30 PM
muteboy49's Avatar
Car: 84 Camaro
mine are threaded as little as possible on the core support and i can barely put my clip things in
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
cougar20th
Aug 27, 2015 08:04 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
bryan623
Aug 10, 2015 11:33 AM
