sick of searching
Old Jan 3, 2006 | 02:48 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
sick of searching
So i have searched continuosly and have not found the thread i'm looking for. I remeber seeing somewhere a full write up of how someone put a 2000 dash in a camaro. I ask this becasue i have the entire interior for a 2000 z28 and the drivetrain. I really would appreciate a response on this. At least a link to another thread. Any help would be appreciated.
Thanks,
Brandon
Old Jan 3, 2006 | 03:38 PM
Frank89IROC's Avatar
https://www.thirdgen.org/techbb2/sho...ash+in+3rd+gen
Old Jan 3, 2006 | 03:56 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
thanks i have read this a couple times and it really doesn't do much but say to try whatever works. I was kind of looking for the thread that talks about where to cut the supports and where to mount the dash to the firewall. This is the only thing holding up my ls1/4l60e swap so i am kinda desperate to make this work. I have also been worried about mounting the center console as the console from the car is an auto console. I don't know if anyone else has a helpful thread but something regarding this would be helpful:
Where do you mount the dash to the firewall?
Where do you modify the existing dash supports?
How bad is the install of a auto console if your using a 4l60e?
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
i just became a senior member!
Old Jan 3, 2006 | 06:17 PM
Hawks did the LS1 to 3rd gen swap and was detailed in "High Performance Pontiac" magazine. In this page, he's saying to call him or e-mail if you have any questions: http://www.hawksthirdgenparts.com/92_formula_ls1
Otherwise try to secure the back issue from HP Pontiac, I subsribe, I'll see if I still have it. After a while though I give them away.
Old Jan 3, 2006 | 06:39 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Have you seen this thread:
https://www.thirdgen.org/techbb2/sho...en+camaro+dash
The guy makes it sound like it isn't such a big deal...
Old Jan 4, 2006 | 10:08 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
that was actually what i was looking for. Thanks. I was wondering though, i haven't seen much written up on the heaters controls. Will i have trouble getting my heater to work? I am not running a/c so i just decided it would be easier to run some ducts to the feet and defroster and not really worry about the dash vents. I hate how everybody makes it seem so easy but i know i am gonna freak when it comes time to actually swap.
Old Jan 4, 2006 | 11:02 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
oh and what if the airbags were deployed. I am going to reuse my steering wheel so i would really only have to worry about the passenger side. I don't have one their from the factory so would i just remove it and seal the flap down?
Old Jan 5, 2006 | 10:04 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
heater controls?
air bags deployed?
anyone?
Old Jan 5, 2006 | 06:17 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
For the heater blend door you can use the cable from an s10 and mount the cable the opposite way. As for the airbag, I just removed it from the dash assembly before I installed it. I hope this helps.
Old Jan 5, 2006 | 07:59 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
ever blow an airbag out of a car? put it face down with 25 feet of wire connected, touch it to a car battery and it'll launch about 50 feet in the air
Old Jan 6, 2006 | 10:50 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
aren't they kind of expensive to do that?
Old Jan 6, 2006 | 01:31 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
shouldnt you put more then 50 ft of wire on it... you know if it goes 50 ft in the air haha
Old Jan 6, 2006 | 01:39 PM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Actually, I belice you have to replace them every ten years, blown or not, because they degrade over time.
Old Jan 6, 2006 | 01:54 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
My friend recently got into an accident in his 00 z28. He spun and hit the wall 6 times driving down the freeway on a rainy day. He said he hit the wall, hit his head on the steering wheel and then got hit in the chest by the airbag. He said the worst part of the crash, was getting hit by the air-bag. Honestly, if i wasn't gonna get a huge fine, i would take the airbag out. I haven't known more people get hurt in an accident by the air bag than without. The only ones that were protected by the air bag were the ones without seatbelts. I always wear seatbelts and am scared s***less of the airbag.
Old Jan 6, 2006 | 02:07 PM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
Luckily for me, I can't even afford a car new enough to have an airbag.
Old Jan 6, 2006 | 03:04 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
your 91 doesn't have one?
Old Jan 6, 2006 | 03:19 PM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
Nope. Cheap bastards at Ford.
Not that I care to much. I got it when I was 17 years old, I had just started working full-time, and I desperatly needed something to get myself back and forth to work. It gets the job done, barely.
Old Jan 6, 2006 | 04:08 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
yeah figures, i read 91 bird and assumed firebird
Old Jan 6, 2006 | 04:13 PM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
No such luck. I'm close to getting an L98 IROC, but the guy's bank is flipping us some BS.
Anyway, I think we hijacked this topic long enough.
Old Jan 6, 2006 | 04:15 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
screw that, this was my thread!! yeah i think youre right though
see ya
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
Linson
Oct 1, 2015 09:50 PM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
