fender allignment
Old Jan 8, 2006 | 06:28 PM
chevybenz's Avatar
Car: 92 RS
Engine: 3.1 L
Transmission: Manual
fender allignment
From the top view, I am wondering if the fender is sitting right with this subtle gap, or if the door and fender should meet flush. In other words, is the door recessed a little bit inward in relation to the fender?
On the side of the car Im repairing, the used fender lines up perfectly flush with the door, and even though the difference bewteen the sides is not noticeable, I want to do it right.
Old Jan 8, 2006 | 07:35 PM
C. W. H.'s Avatar
Car: 1989 Firebird Formula 350
Transmission: 700
Is/are the fender(s) shimmed? That my be your problem.
Old Jan 8, 2006 | 08:20 PM
chevybenz's Avatar
Car: 92 RS
Engine: 3.1 L
shimmed?
What do you mean?
Old Jan 9, 2006 | 02:53 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
there are body shims they are a spacer to move fenders out. They are used alot in collision repair i don't know if they came out of the factory with them or not my car didnt have them when i tore it down. sorry for the limited help
Old Jan 9, 2006 | 03:26 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Is the space the same on the tops and bottoms as well?
You may just try pushing in on the fenders a bit.
Old Jan 10, 2006 | 06:37 PM
bfox88's Avatar
Car: 90 IROC-Z
i just replaced my fender and there seems to be a smaller gap between the fender and the door, as opposed to the original fender on the other side.
Old Jan 10, 2006 | 09:31 PM
chevybenz's Avatar
Car: 92 RS
Engine: 3.1 L
its weird....the stock side has the gap, the side i fixed is flush...i like the stock side better. Ill have to mess with it more.
Old Jan 10, 2006 | 09:52 PM
92droptopbird's Avatar
Car: 1992 firebird convertible
Engine: 305 TBI
Transmission: 700 R4
I also just replaced a fender, mine was recessed about .5" inside of door. Most aftermarket fenders are not an exact match, but with some gentle persuasion, they can be made to fit very nearly as well as stock....just don't get frustrated and try to do too much at one time...take your time and make subtle adjustments!
Old Jan 10, 2006 | 10:19 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Most vehicles have the front fenders out a bit farther than the doors, there are a few reasons for it:
It reduces wind noise
and
it stops your door from getting rock chips along the edge and starting the paint to peel.
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
