Bouncing Headlight
Old Jan 14, 2006 | 08:37 PM
Dragonsys's Avatar
Car: 02 TransAm
Bouncing Headlight
My driver's Side headlight bounces while I drive. Even when the lights are off and down, it is still loose and moves around some.
I have looked at it, but I can't see any bolts which might be missing or loose. Are there any under the light assembly which might cause this? This is very annoying while driving at night...
Old Jan 14, 2006 | 09:22 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
did u make sure the ring that retains the headlight is holding the headlight? best thing to do is the shake test. grab ahold, shake the unit and look for the play
Old Jan 14, 2006 | 09:25 PM
Dragonsys's Avatar
Car: 02 TransAm
The whole housing bounces, not jus the bulb. I can see it as I'm driving. Even with the light down, I can shake the housing.
I have held the housing and moved it, trying to locate the loose point. It seems like it might be near the back/bottom of the housing, but I can't see any bolts/holes in that area.
Old Jan 14, 2006 | 09:38 PM
Car: Trans AM
Engine: 305 TBI LO3
if i can get the ice off my car ill take a look for u tomorrow, maybe its just loose where it mounts to the body/frame
Old Jan 16, 2006 | 12:10 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The are A LOT of adjusting screws on the popups headlights.
There are two that bolt the headlight bracket to the core support up top, there are the two each that bolt those brackets to the headlight assembly and there are two more below the actual headlight that bolt it to the cor support on the bottom.
Make sure all six are tightened down and the speed nuts they screw into are secure.
Old Jan 16, 2006 | 03:35 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What was said above is a start.
Also in higher mileage cars, the side rods actually start to wear.
The long pieces that hold the headlite in the up position.
They have rounded snap circles on the end made of plastic, these go onto metal ball studs.
If they wear and get play they can do the same thing if its a headlite up issue.
Either replace if u can still get parts or a light light coating of epoxy or equivelant to the inside of the ball(just a skim layer or you will have too much) and relube and assemble.
A cracked healdite housing is also another great one to cause issues. I have seen ones cracked from wear and wrecks.
later
Jeremy
Old Jan 16, 2006 | 04:56 PM
Dragonsys's Avatar
Car: 02 TransAm
Is there any easy way to get to all those screws and bolts?
Old Jan 16, 2006 | 05:28 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Pull the plastic headlight bezel off for the lower two (I think a 10 or 15 torx bit?). Just reach down inside with your hand and the bolts are a 10mm (obviously like everything else on the car). Three of the others are real easy to spot on the core support and around the headlight. The last one is a pain to reach from behind the core support. I don't remember if I can even reach that one without pulling the whole assembly.
Old Jan 17, 2006 | 01:07 AM
PROCHARGED's Avatar
Car: 1992 TRANSAM 1989 FORMULA 350
Engine: L-98 350
Transmission: FIRM SHIFTING 700-R4
Re: Bouncing Headlight
Check and see if your headlight assm. is cracked at the top were the headlight moves.Open your hood and check behind the headlight assm.while you move the headlight assm.
Old Jan 17, 2006 | 11:19 AM
Dragonsys's Avatar
Car: 02 TransAm
I will check all that out this weekend.
Thanks for all the help
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
