front clip conversion
Old Jan 30, 2006 | 10:16 PM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
ok i've searched and searched for an answer and can't get anywhere!! is the front clip (minus the gfx) on 91-92 the same as the older camaro's i love my 91 rs but i want t-tops would my front end fit on an older say 86?
Old Jan 31, 2006 | 07:25 AM
just2quickz28's Avatar
Car: 86 IROC
i know the front clip minus the areo style gfx are the same from 85 up, but i do believe it will also swap on to an older pre 85 car, someone correct me if im wrong
Old Jan 31, 2006 | 09:38 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It will bolt up, but you might need fenders. If the 86 originally had ground effects, then it should bolt up fine. Otherwise you'll need new fenders. If you look closely at the fenders to a SC or berlinetta, they have a notch thing at the bottom front edge. You can, however put your entire 91 front clip on there, fenders and all.
Old Jan 31, 2006 | 09:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You don't need new fenders. You just may have to drill a couple holes because the front chin studs might be in a different location.
Old Jan 31, 2006 | 10:02 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
so what i understand is that the 85-90 GFX front bumper is the same as the 91-92 bumper, just a different front spoiler bolted to it?
Old Jan 31, 2006 | 11:45 PM
Car: 1991 camaro rs
Engine: 3.1
the body on my 91 is straight so i might just swap the front clip anway. ok does anyone have a t-top rolling chassis for sale cheap? lol
Old Feb 4, 2006 | 07:01 PM
black84z28-4spd's Avatar
everything is interchangeable....all i had to do was drill the holes for my 85-90 gfx
ktthecarguy
Jul 5, 2020 11:46 AM
3tas4me
Sep 4, 2015 01:45 PM
lt1z350
Aug 28, 2015 05:57 AM
dag19
Aug 26, 2015 10:22 AM
stalkier
Aug 13, 2015 12:59 PM
