rear trunk panel
Old Feb 1, 2006 | 10:31 AM
PAformula's Avatar
rear trunk panel
Is the rear trunk panel different for cars with pull-down motors? Basically what I need to know is will a panel from an early 3rdgen fit a later 3rd gen with a pull down motor.
thanks
Old Feb 1, 2006 | 03:24 PM
MNformula350's Avatar
No, the ones for the pull down are shorter, due to the clearence necessary for the pull down assembly. 82-85 will interchange, and 86-92 interchange.
Old Feb 1, 2006 | 03:26 PM
PAformula's Avatar
THANKS
Old Feb 3, 2006 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Some of the 1982-85 panels also had a slot for an alignment pin. Not all slam hatch latches had this alignment pin.
Lon
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
