Never thought I would ask this about a car - 3rd gen rust spots
Old Feb 4, 2006 | 10:32 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'm going to look at a 92 RS. T Top, 305, 90k miles. Only thing is its an Illinois car - guy just moved to California so i'm a bit weary about rust. He claims he and the original owner kept great care of it and never drove it in the snow yadda yadda...I still would like to see for myself. Where, besides the obvious wheel wells is rust likely to form? If there is rust, how much is "too much" and at what point is it easily repairable?
Old Feb 4, 2006 | 11:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Common points of rust I'd say are:
1. Floor pans, right where the front driver's and passenger's feet rest
2. Wheel wells, you should be able to see it.
3. Front strut towers, once again, noticeable
4. Lift the rear hatch and look up (bottom of the hatch)
I'm sure there's more, people will chime in.
Old Feb 5, 2006 | 12:37 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
Check where the spare tire sits, mine had a small amount of rust (now removed) there.
Old Feb 5, 2006 | 10:48 AM
tagta189's Avatar
Floor pans big time.Being from Illinois I can tell you where the big rust problems are.First like they said where the drivers and passengers feet rest,and also behind the front seats right along the rocker panels.That is usually the first spot to rust.Also behind the lower rear part of the front fenders,where the leaves fall down and sit along the bottom there and hold water and moisture and rust the crap out of everything.Good luck..
Old Feb 5, 2006 | 11:55 AM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The front edge of the hood usually gets kinda rusty on these cars. Obviously, you should check around the T-tops. And I think they covered just about everything else.
Old Feb 5, 2006 | 12:47 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
remove the ttops and move the weatherstripping back with your hands. especialy along the tbar. there is almost certain to be rust here. as long as there are no holes i think your good, but it should turn that 3,000$ into a 2,500$ or less real quick once you point it out to him. if he will let you pull up the carpet on the drivers side DO IT. bring a philips screwdriver. you will be glad you did.
Old Feb 5, 2006 | 04:19 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Will I be able to see the rust where the drivers feet go by looking under the car? Or do I have to pull the carpet?
Old Feb 5, 2006 | 07:06 PM
tagta189's Avatar
If you bring a mechanics telescoping mirror and a good flashlight you should be able to look under there and see what you need to see.Have a real good look on the floor pans along the front and rear where they meet against the rocker panel.
Old Feb 6, 2006 | 01:56 AM
johnyIROC's Avatar
Check around the windshield... if there is any rust then there is a good chance the entire windshield frame is toast. This is one of the hardest parts to replace.
Old Feb 6, 2006 | 03:29 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
Dante was unaware of the rust belt states when he wrote about the circles of hell!!
is it a t-top?
Old Feb 6, 2006 | 03:31 PM
Engine: 5.0L 305 H
Old Feb 6, 2006 | 03:33 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Yes T-Top.
Old Feb 6, 2006 | 07:53 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
Another common place for rust to form is on the a pillars on the outside of the vehicle. I have some on my passenger side pillar and lots of people have rust on the driver side as well.
Old Feb 6, 2006 | 08:13 PM
Pocket's Avatar
Car: 91 Trans Am
Didnt see this listed, but the battery tray almost ALWAYS rusts out northern/soutern cars
Lower radiator support is normally soft
Simple test if rust is BAD
Take a small screwdriver and jab the ugly parts of a rust section. If it goes thru/flakes off big chunks/feels soft and spongey, then its bad
If it doesnt flex and gives the satifyin 'bonk' then its jsut surface
Old Feb 6, 2006 | 08:37 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
How does one go about repairing various types of rust? If there is surface rust can that eventually get worse into structural rust? Can I just sand away surface rust and be done with it? Or should I paint over it with some kind of sealant?
Old Feb 6, 2006 | 11:27 PM
subliminal's Avatar
Yup you can, just use POR-15
Old Feb 8, 2006 | 12:15 PM
Ratchet's Avatar
Very minor surface rust can be repaired by cleaning with Naval Jelly then, primed with epoxy and painted. Check hotrodders.com for how to instructions.
Any other rust must be amputated and repaced with new steel.
Very minor surface rust is pretty rare. Most rust needs to be amputated before it infects the rest of the body.
Ric
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Leggman1
Aug 6, 2015 04:15 AM
