Lower door hinge
Old Feb 8, 2006 | 05:10 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Lower door hinge
I need a lower hinge on the driver side... anyone know where i can find one of these? i looked on hawks and its 100 bucks just for half of the hinge!
Old Feb 8, 2006 | 05:29 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
half the hinge is typically ALL you need (with the addition of a new 'pin')
Replace that half hinge put in a new pin and you are great for another half a life time....
I've put in 3 of them now and they make all the difference in the world.
One problem I've found is that the new one only has 2 holes drilled . Last time I tried to put one on without drilling that third hole, I never could get to line up properly.
Drill the third hole..use your old hinge piece for a template as to where to drill.....
$100 is what you are going to pay for a new one.....don;t think you would want a used one as you would probably experience the same issue you now have....droopy door....
The new hinge piece will come with the bushings alreadt there and will insure a good fit of your NEW pin.
Suck it up and buy the part......
Old Feb 8, 2006 | 07:11 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
im not sayign that its expensive.. i was just asking if there was anyone out there that was selling thenm for cheaper
Old Feb 8, 2006 | 08:51 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Fl GM dealership
I just completed this on my camaro. I ordered them from a FL dealership. They were less than $60.00 each plus shipping. The contact at the dealership is Jason Cromer. The number is 1-877-726-8295. He will give you a break on shipping too unlike gmpartsdirect.
Also, drilling the third hole in the door hinge is kinda tricky. You can't just line up the passenger side to passenger side and mark the holes. The third hole is not center in the hinge. I know it doesn't make since but you have to use the drivers side as a templete for the passenger side and visa versa. I c-clamped them together and drilled it that way. Wish I would have taken pictures now. Maybe someone else can explain it better.
Old Feb 8, 2006 | 08:59 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
thanks ill call him toamrrow.. i found a reputable body shop that will do it for 15$
Old Feb 8, 2006 | 09:05 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am having the same problem on my 85. There is a 92 RS at the JY with perfect hinges and I was wondering if it is easier to replace the whole hinge set or just the pins? I can pull the complete hinges and all for nothing but is it a PITA to replace them? I will do a search but chime in if you know.
Old Feb 8, 2006 | 09:29 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Junkyards will be hard to find a good set. it depends on your problem. wiht mine the bushings were gone for a while so the hole was made bigger which is the reason why i need a new hinge.
pon will he know what im talking about when i call or should i give him your name and help some memories come back?
Old Feb 8, 2006 | 09:30 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
82. if your pin needs to be replaced it would be easier and maybe more cost effective to get the whole hinge replaced.. the door has to come off for both anway
Old Feb 8, 2006 | 09:32 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Have you done it before? Can I do it, or should I take it to a shop to have it done?
Old Feb 8, 2006 | 09:48 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
you CAN do it yourself... doa search on door hinge pin. i was doign that but then i shopped around for local body shops. 15 buck vs 1+hour and a head ache.. i dont think its worth trying yourself but maybe your the type who likes to complete stuff on his car himself? jsut doa search. theres a spring that causes headaches
Old Feb 8, 2006 | 09:52 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well I am a do-it yourselfer and I have read about the pins, but I am thinking about getting the complete hinges from the 92 removing my doors and hinges are replacing them. Is it easy or a PITA?
Old Feb 8, 2006 | 09:55 PM
pondriver's Avatar
Engine: 350 HSR
I'm pretty sure he wont remember. He works in the parts department. I was referred to him by this website. I have part #'s somewhere but if you just tell him you need the lower hinge body side that should do it.
Normally the top hinge is in worse shape than the bottom. I changed them because my rollers were shot. If you intend to do the bottoms you may as well do the tops also. Unless you know someone I doubt any body shop doing it for $15.00. I also installed the greasable top bushings/pins from top down solutions. This was my first try but it took me a good 8 hours to do the top and bottom. Check out this thread for lots more info.
https://www.thirdgen.org/techbb2/sho...hlight=andyz28
Remember too the hinges are welded to the doors. That's alot of work to replace a complete used hinge.
Old Feb 9, 2006 | 06:52 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
thanks. i really doubt that my door side hinge needs to be replaced thus the low price. or atleast it doesnt.
Old Feb 9, 2006 | 09:11 AM
pondriver's Avatar
Engine: 350 HSR
I was referring to this about changing the door side hinge. They are welded and require alot of work for a used hinge. I didn't buy the door side. I purchased the body side and installed them.
Old Feb 9, 2006 | 03:22 PM
pondriver's Avatar
Engine: 350 HSR
Pics for who cares
Old Feb 9, 2006 | 07:20 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
My doors sag a bit and I was talking to my father in law today. He told me I could buy a set of spacers from Autozone to put on the bottom hinge and it would fix my problem. Ever heard of this?
Old Feb 10, 2006 | 01:01 AM
stitchop's Avatar
Car: 91 firebird
Yeah, and next year you can get another spacer and then another the next year and so on until you have a 2 inch stack of them.
Actually this is not an option because the hinge is welded to the door and that is the side you would have to put the spacer behind. Besides, if you where going to loosen the hinge to put a spacer in, why not just change the pin and bushing?
If the hinges have not worn enough to ruin the hole for the bushings, than changing the pins and bushings is not difficult at all.
Old Feb 10, 2006 | 03:12 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
I took the repair route to fix both sagging door hinges. First door took a little more than three hours, second one a little more than two. Installed new lower body sides and installed the upper greasable top bushing repair kit sold by tops down solutions. Not counting the value of my time to repair both doors, the hardware alone set me back close to $400+-. You may be able to locate new lower body side hinges for less than I did but the upper repair kits are priced pretty much the same to all of us. It's not a cheap repair but, it works.
Old Feb 10, 2006 | 06:53 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I picked these up today from a 92 RS along with the lock actuators for $5. Is this even doable or should I take it somewhere or buy all new hardware? It was a PITA just removing the pins and I don't wanna mess up my car because it has new paint?
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
BHR
Sep 3, 2015 07:51 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
