spinning visor pin!
Old Feb 12, 2006 | 01:22 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
spinning visor pin!
anybody know how to repair the visor pins that, over time, seem to loosen and thus prevents the visor from staying put. were they just pressed it? tried epoxy...but, short of welding the pin to the mount.......
Old Feb 12, 2006 | 01:43 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Fold down the sunvisor and there should be a screw on the visor to tighten. Worked perfectly on mine.
Old Feb 12, 2006 | 02:20 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I picked up about ten at a local yard for $2.50 each. There are a few different styles so make you grab the correct ones.
Old Feb 12, 2006 | 04:19 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the pin, the piece that inserts into the visor, turns in its housing/hanger, tightening the visor won't help. Hit the bone yards; every thirdgen has two hangers.
JamesC
Old Feb 12, 2006 | 04:26 PM
Car: 86 T/A
Engine: HSR 355
Oh I get it, the other end of the visor mount. Yeah, just pick some up at the junkyard if epoxy doesn't work.
Old Feb 12, 2006 | 04:32 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
There is actually a plastic bushing that goes bad. Loosen the screw all the way and pull the visor mount from the visor, look inside the visor and there should be a plastic bushing, pull it out and replace it with something similar or grab a good set from the JY.
Old Feb 12, 2006 | 05:04 PM
JamesC's Avatar
If the pin is loose from the housing/hanger, replacing the plastic insert will do no good. Remove the visor and try to rotate the pin with your fingers (may require a bit of jiggling). If it rotates, replace. If not, consider tightening the visor to the pin and/or replacing the insert.
JamesC
Old Feb 12, 2006 | 05:10 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
JamesC
True that, do you need one from a t-top or hard top car, I have a few floating around.
Old Feb 12, 2006 | 06:52 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I had the same problem- I just used some epoxy to glue the pin in place. Has been holding for 2 years.
Old Feb 13, 2006 | 11:44 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
I would be carefull because I tried to tighten my passenger side visor and the bolt head broke off
Old Feb 13, 2006 | 12:03 PM
wdigitog's Avatar
thanks guys...i'm trying the epoxy! the roads here in new york are so uneven....and with my stiff suspension..the vibs are shaking the pins loose! yea, the visor to pin connection is fine...it's the pin/post to housing connection that's the prob..
Old Feb 14, 2006 | 01:31 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've used epoxy. I've also used a center punch to dimple the bracket enough to impinge on the pin to keep it from rotating.
Lon
Old Feb 14, 2006 | 06:53 AM
wdigitog's Avatar
really? i was scared to do that since they're cast! they didn't crack?
Old Feb 14, 2006 | 07:06 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have brand new ones from 1a auto. junk, I think that I am going to use some weak velcro.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
PurelyPMD
May 5, 2016 04:57 PM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
