anybody install these sub frame connecters?
Old Feb 21, 2006 | 04:26 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
http://store.summitracing.com/defaul....asp&x=36&y=10
seeing if anyone installed these sub frame connecters on there car, if so maybe pics? i bought a set of a guy for really cheap not used. I started thinking if it worth it or not, ive got a 8 point cage too.
Old Feb 21, 2006 | 05:04 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if you dont mind cutting through the floor board to install them, then they're worth it. those are straight and therefore need floorboard mods to work. but it's just a 2inch wide strip that needs to be cut out however long it takes to line up. i think it was 2x14 on the car i saw them on.
Old Feb 21, 2006 | 05:10 PM
IROC_5796's Avatar
dont suppose you have any pics? im mostly worried about the space left under the seats
Old Feb 21, 2006 | 07:34 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The Summit site has instructions.
Old Feb 21, 2006 | 07:36 PM
xpndbl3's Avatar
Car: 1984 Z28
why do you need space under the seats? i don't think anything fits under there worthwhile.
Old Feb 21, 2006 | 07:38 PM
IROC_5796's Avatar
i realize theres instructions, i just wanted to see if anyone had a pic of how the interior of the floors looked after to ensure theres still enough room for the seats in the front, im not using back seats so that doesnt matter.
Old Feb 22, 2006 | 09:18 AM
bshade's Avatar
Car: 1988 Firebird trans am vin E
Engine: 305 TBI
Transmission: 5-speed
Are any of the other sub frame connectors better from summit? I had those same ones in my wish list and was about to purchase. I just wanted to konw if another set of them would be better, I am not to interested in cutting out my floo pans. I guess you can weld the floor pans to the sub frame connectors to the floor pans to seal them off, but I am not sure.
Old Feb 22, 2006 | 03:22 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
if you got a welder id say just save some cash and make your own those ones look very simple.
Old Feb 22, 2006 | 03:38 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Theres plenty of other sfc out there from places other then Summit. Spohn, Alston, etc... Or you can just have a chassis shop make some for you. That's what I did. Cost about the same as buying them. Plus they fit alittle better since our cars tend to not stay in spec for long.
Old Feb 22, 2006 | 06:53 PM
IROC_5796's Avatar
https://www.thirdgen.org/techbb2/sho...e+of+underside
the summit ones are made by competition engineering, if you look at the seccond pic on that link you can see where these one might work with a little modification of course
Old Feb 22, 2006 | 07:30 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
i searched for weld-on SFC's for my car, and it came up wtih 3 different ones. http://store.summitracing.com/defaul...=egnsearch.asp
now...one pair says "not for convertibles", one says "without ladderbar crossmember" and one says "with ladderbar crossmember"
do i need the ladderbar cross member to see a great difference in handling? and is there a certain type i need to buy that will fit on my car seeing that it's a convertible?
Old Feb 22, 2006 | 08:54 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
hotchkis makes a good set of SFCs.
Old Feb 22, 2006 | 10:21 PM
IROC_5796's Avatar
ladder bar for drag cars and 4 link maybe and i think convertables come with factory installed frame connects so the aftermarket may interfere.
Old Feb 23, 2006 | 12:28 AM
bshade's Avatar
Engine: 305 TBI
Spohn has them for convert. and theres seam to be really nice. I was doing a lot of reading on spohn today. I will be going with them. And a lot more from them, pretty much the entire bottem end of the car + a roll cage.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Caspar
Jun 19, 2016 11:19 PM
