worthless fuel gauge
Old Feb 24, 2006 | 05:23 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Alright so anyone else have one of the camaro fuel gauges where they like to go from full to empty when slamming the brakes or going around a turn? Ok maybe not that much but after a half tank my gauge is very hard to follow with how much gas in actually in the tank. Frequently going around turns it will go into empty and come back up. I know the float must be sloshing around a lot but is there any fix for this. I just want to make sure its common with all f-bodys and not just mine...my gf's 89 RS does it and it seems to be worse with her car...
Old Feb 24, 2006 | 05:32 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Get a gas tank with baffles is about the only thing you can do to fix the problem. I hate how I cant take a corner or a big curve with anything less than half tank or my car will start to sputter and die because all the gas is on one side of the tank.
Within the next year or so I plan on swapping my current tank out with a plastic LS1 tank.
Old Feb 24, 2006 | 06:08 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Same goes with my car.
Old Feb 24, 2006 | 07:12 PM
Stevo's Avatar
retarded.
lol.
Old Feb 25, 2006 | 01:55 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
I have that problem.
Ill put my brakes on really hard and BAM, it goes all the way to empty, then crawls back up.
I hate GM fuel gauges. They are horribly inaccurate even with the modern ones.
Old Feb 25, 2006 | 12:26 PM
j dezzy's Avatar
Car: 87 TA
My G/F's 87 camaro does that too. Best idea is to do what was previously mentioned, a tank with baffles. I put one in my bird and never had the problem again.
Old Feb 25, 2006 | 05:00 PM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
GM guages are purposely optimistic and pessimistic. They show full even after you have used several gallons and show empty when you still have some left. GM's argument has been that it inspires confidence by the driver, and helps keep people from running out of gas. Illogical points, but then, when was the last time GM was ever logical?
Old Feb 25, 2006 | 06:23 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
ya i have run my car for days back and forth to work on empty and the closest to an empy tank i have had was 1 gal short of a 15 gal fill.
Old Feb 26, 2006 | 01:10 PM
BABYBLUE_RS's Avatar
Car: 1992 camaro RS
Engine: 305 cu.in.
Transmission: automatic
Axle/Gears: stock
mine also does the same thing but my 92 z28 never did it at all?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
