How to fix the rolling cargo shade cover?
Old Feb 26, 2006 | 06:42 PM
Firebat's Avatar
I got 2 broken ones. One looks like it will work but it is 4 inches short from side to side and won't let me install it in the back. The other doesn't want to roll back up on its own.
Old Feb 26, 2006 | 11:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I fixed mine some years ago,So this may work for you, but its a little hard to explain.Anyway,If you roll out the cover,then continue to rotate the bar past the point it stops(you'll have to somehow fold the edge of the cover around the plastic end caps as you rotate it).At the same time someone has to hold the ends from rotating.Only the bar should rotate with the cover.Do about 5-7 revolutions.As you complete a turn check to see if the bar wants to turn backwards(or roll up).If you've done enough revolutions the cover will rotate all the way back.If not try a few more revs.This work for me, but only after 2-3 trys.So far though my cover still works fine after 3+ years.Good luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
