Why won't the dash pad screws come out?
Old Mar 5, 2006 | 04:11 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Pretty simple question, and I feel dumb for asking it, but I need help... Three of the four dash pad screw up front, near where the defroster area and speaker grilles are, will not come out! The first just did it's thing, then none of the others will actually come out... I keep turning them, they stay put. I don't think they are stripped, because they are at least firm to turn...
Basically, I think you all will tell me that they are stripped.. I know they worked recently, because my pad was pulled los of times for speakers... Any thought?
PS: I'm not as dumb as this post makes me seem..
Old Mar 5, 2006 | 04:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
they're stripped, try shoving a flat bladed screwdriver under the phillips head and prying up while turning a phillips headed screwdriver and you should be able to slowly turn and pry them out.
Old Mar 5, 2006 | 04:20 PM
Car: 1982 Z28
Engine: 350 HO
Originally posted by xpndbl3
they're stripped, try shoving a flat balded screwdriver under the phillips head and prying up while turning a phillips headed screwdriver and you should be able to slowly turn and pry them out.
Dang, figured as much.. but thanks for how to get them out, I'll go do that..
Old Mar 10, 2006 | 10:53 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you could also try tightening some vicegrips on the head and pulling as you turn them. I'd be affraid that I'd crack the dash by prying with a screwdriver
Old Mar 10, 2006 | 12:31 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I had the same problem with remvoing the screws in a parts car I had. I ended up using a flatblade as mentioned above. Just take your time. If you start to get frusterated, just walk away man- walk away.
Old Mar 10, 2006 | 12:34 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Once you know they are loose, use a magnet to pull them out enough to get your fingers on them.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
