how do i get my ground effects off
Old Mar 26, 2006 | 06:19 PM
adidas222420's Avatar
Car: 1989 IrocZ
Engine: 5.0 TPI
Axle/Gears: 3.43 rear disc brakes
sanding my car and i realy need to know how to take the ground effects under the door off can anyone help?
Old Mar 26, 2006 | 06:32 PM
chevybenz's Avatar
Car: 92 RS
Engine: 3.1 L
Transmission: Manual
what year and type of car would be good to know
Old Mar 26, 2006 | 06:36 PM
Car: 1989 IrocZ
Engine: 5.0 TPI
89 iroc z
Old Mar 26, 2006 | 06:46 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
The piece on the actual door you have to take the door trim off and there's nuts inside of the door. For the side skirts there are several screws underneath, two underneath the emblems where it would say z28, and one at the other end that goes into where the back seat is. You have to take some of the interior trim off to get at that bolt. It's a 11mm nut and you'll need a deep socket.
Old Mar 26, 2006 | 07:01 PM
Car: 1989 IrocZ
Engine: 5.0 TPI
took off all the out side bolts on the bottom so under the iroc sym. and where under the seat huh?
Old Mar 27, 2006 | 01:42 PM
Yes it's next to the rear seat cushion behind that trim piece.
Old Mar 28, 2006 | 05:05 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
And if it would be a convertible it's almost impossible to get to. I have the same problem (88 convert) and could never get to the nut any kind of way.
Old Mar 28, 2006 | 05:06 PM
88ragtop's Avatar
Engine: 305 tb
Transmission: auto
And if it would be a convertible it's almost impossible to get to. I have the same problem (88 convert) and could never get to the back nut any kind of way.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
