the rear quart pannels fixable? PICTURE
Old Mar 27, 2006 | 06:35 AM
88firebirdguy's Avatar
Car: 83 recaro, 82 grandprix, 72 skylark
is this rust here fixable? it seems that the paint bubled and rust came through, some places i can actually pull of large chunks off
the bottom of the pannel has alot of rust and then all the way around the wheel well as you can see in the picture. lucky i found a spray paint that is a perfect match for the factory paint and has made the car look better for the year i have driven it now.
what are my options with it? cut off a whole pannel from another Firebird? patch it? just leave it? get rid of the car all togther?
i do have a 110 volt lincoln welder but havent added on the gas yet, i have used it a little bit with not much luck so welding is not really a option right now.
Old Mar 27, 2006 | 01:05 PM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
From the picture it appears that rust is inside the door jam as well. I would recomend welding in a new quarter. just the face can be had for under 100 from year one, the OER panel runs closer to 400 but will turn the corner at the door jam and get rid of the rust that you probably have in the bottom right corner when you open the door
Old Mar 27, 2006 | 02:10 PM
i just checked out year one and they have them for $82 a piece but how high up on the car would it replace?. Theres no pic on the website to know.
Old Mar 27, 2006 | 02:17 PM
jay92,85,79's Avatar
Car: 85z28,
It all depeands on how much u like the car or how long u going to keep it.. I would say get some rust stoper (sem) makes a goos one. And fix that 1/4 . The reason for me saying to fix it is. It is going to be hard to weld on a new 1/4 cuz all your inner metal is going to be rusted to.. U can not weld to rust.. So u will have to replace alot more parts..
That would be the right way.. But u can pick up a hole not rusted out 3rd gen for pretty cheap.
Old Mar 27, 2006 | 02:24 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Personally I'd save your money and keep on eye out for a better body.
Old Mar 27, 2006 | 02:39 PM
The rust does not go into the door jam it stops on the corner. i checked under the carpet and there is absolutly no rust at all, rocker pannels are good as well and same with the underbody. i was told by a mechanic that the rear shock mounts rust out alot on these cars and mine have no rust there as well. seems only the outer body is going to crap(i think the car was in a accident in 88-89 and repainted maybe it was done wrong and moisture was traped between the paint?) i have already goten new hood, front quarter pannels, and passenger door, i would just need to get the rear quarts and drivers door.
it is just a daily driver and will never be for show, mostly just for winter driving. ethier going to keep it and fix the body and paint it myself to get it half decent looking and pull the motor and replace all the gaskets and some other stuff or sell it and move on to a newer daily Driver.
Very hard decision, have had it for a year and have gotten attached to it. if i get another car it wont be a firebird or camaro as its so hard to find one for half decent price that hasnt been run the **** out of its whole life. i was lucky with this one, doesnt look good with its rust but has been mechanically great. 1 owner lady used it for highway driving to work. it now has 135,000 miles on it.
Old Mar 27, 2006 | 05:57 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Have fun with that one.
Old Mar 27, 2006 | 06:14 PM
meaning what?
Old Mar 27, 2006 | 06:28 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Thats a major case of body cancer.. Id be looking for a better off body..
Old Mar 27, 2006 | 08:34 PM
im thinking im just going to drive it untill i put my summer car on the road and then sell the firebird and go buy a newer car. but i dont know how i will be able to let it go.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 17, 2015 01:29 PM
mizz0313
Aug 12, 2015 06:45 AM
