Steering wheel change Q
Old Mar 29, 2006 | 12:06 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
To remove the airbag steering wheel, do I have to employ the airbag?
Old Mar 29, 2006 | 05:39 PM
Mr. TurboTA's Avatar
Nope!
There are 2 long screws (if I remember right, if not, they are long bolts) that attach the bag to the steering wheel. They come in from the back of the steering wheel.
Then, just unplug some wires in the back, and you have removed the airbag.
Then, you remove the steering wheel like a regular steering wheel.
Hope this helps,
George
Old Mar 29, 2006 | 06:43 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
whatever you do unplug the battery so it dont deploy the airbag!that could do some serious dmage,and plus you could sell it too
Old Mar 29, 2006 | 09:01 PM
ChevyRS-305's Avatar
Originally Posted by Mr. TurboTA
Nope!
Hope this helps,
George
uh...i may sound stupedbut....how do u take off the steering wheel....ha ha
Old Mar 29, 2006 | 10:51 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
I don't know what it means to "employ" an airbag, but you certainly don't need to deploy it
Just check out this tech article:
https://www.thirdgen.org/tech/airbag.shtml
Old Mar 29, 2006 | 11:02 PM
82knightrider's Avatar
Transmission: TH200C....700R4
A steering wheel puller
Old Apr 1, 2006 | 08:04 AM
j dezzy's Avatar
Car: 87 TA
I'm removing my aribag too for an older TA steering wheel. The only issue that I've wondered is this...When the airbag is functioning properly the SIR light will flash a few times when the car is started. It's never happened to me but according to the service manual, if the airbag is not functioning properly then the SIR light will reamain on. If I remove the airbag wheel will the SIR light stay on or will removing the fuse aid this problem?
Old Apr 1, 2006 | 05:15 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
The guy i bought my car from took the airbag fuse out and the dashlight stays on all the time. I just ignore it
Old Apr 1, 2006 | 11:59 PM
MNformula350's Avatar
When I replaced my airbag wheel, I had the dash apart at the time, so I just pulled the bulb for the SIR light.
Old Apr 2, 2006 | 09:43 PM
Pocket's Avatar
Car: 91 Trans Am
I did that with my T-5 shift light, Airbag light, and SES light
Made things tons less cluttersome
Old Apr 3, 2006 | 04:46 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
my friend got in an accident where his air bag deployed, and he got chemical burns all up his arms! so deffinetly do that! you dont want that all up in your grill.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
