Mounting a digital Camera?
Old Apr 1, 2006 | 04:34 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just got the idea to mount my digital camera in my car(82 TA) for Auto-x. The camera is a Canon PowerShot A250. It's not ideal for recording, but it will help. I'm not really sure how to go about mounting it though. Any ideas?
Old Apr 1, 2006 | 08:06 PM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
Get a cheapo tripod and duct tape/wedge/whatever it behind the center console, infront of the rear seats.
Old Apr 1, 2006 | 11:23 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Find a bolt that will screw into the hole at the bottom of the camera. Then, mark where you want it to mount, take the dash off, drill a hole in the spot, insert the bolt where the threads are coming out of the dash, and then use a nut to keep it from going back through. I would use washers on both sides too so it would have less of cracking the dash and falling back through. Then you could simply screw the camera on the dash and you would also be able to turn the camera easily.
Or if you would want a less permanent solution, some strong velcrow(sp?) or magnetic strips on the bottom of the camera and dash could work.
Edit: Im assuming that bottom hole has threads, if not, u could take apart a stand that u can buy from the camera(which is why that hole is there) and use the same principle as the bolt idea.
Old Apr 2, 2006 | 07:41 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
go to www.supercircuits.com
cheap small cameras!!!
MantyZ28
Nov 8, 2015 06:54 PM
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
