Rear Hatch Lock Unit Question
Old Apr 13, 2006 | 01:39 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I peeled off my back panel, and found this:
Tell me, is that what a manual hatch lock unit looks like? Just seems like alot of useless stuff for a manual hatch.
Don't bother telling me to search, because I have and found 0.
Old Apr 13, 2006 | 01:53 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's electric.
Old Apr 13, 2006 | 01:54 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Care to explain? Does that mean me installing a button for electric hatch release, it should pop?
Old Apr 13, 2006 | 02:02 PM
Car: 86 T/A
Engine: HSR 355
There are two parts to the hatch release assembly. The solenoid, which "pops" the trunk. And the motor which moves the trunk lid up and down. I see a motor there, so when you close your hatch it should pull it down. I don't really see a solenoid but I'm not sure since the later years are a bit different than my 89's trunk. You can buy the solenoid if there isn't one there, wire a switch to send 12V to it, then it will pop your trunk.
Old Apr 13, 2006 | 02:07 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Interesting. My hatch motor doesnt pull down my hatch. Where should I start to fix this.
Old Apr 14, 2006 | 01:28 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You need to post a picture of the other side of the pull-down motor. From that shot I can't tell if the striker-sensing switch is present. I have fewer parts available for the 91-92 style pull-down motor, (which is what you have). I do stock the guides, striker-sensing switch, reversing switch and gear nut.
Lon Salgren
Top-Down Solutions
Old Apr 15, 2006 | 11:13 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Thank you for your response, here is the picture:
lmk
Old Apr 15, 2006 | 04:25 PM
lonsal's Avatar
Post a close-up picture of it from the rear of the car. The opposite side of what you've shown so far is where the striker-sensing switch is located. Also does your hatch light turn off when the hatch is closed?
Lon
Old Apr 16, 2006 | 05:14 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
No, the light doesnt work.
Old Apr 16, 2006 | 09:35 PM
lonsal's Avatar
The switch is there, but the hatch light failing to work means either the fuse or the switch is bad. The striker-sensing switch on your 91-92 pull-down motor turns on and off the hatch light.
Lon
Old Apr 16, 2006 | 11:16 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Ok, Ill check the fuse first. You dont know off the top of your head which fuse it would be, would you?
If the fuse turns out to be good, Ill have to replace the striker switch, right? Will I need the reversing switch and relay too?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
