Crazy hood gap!
Old Apr 21, 2006 | 11:52 AM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Crazy hood gap!
I just installed my Harwood 4 inch cowl hood and now i have this massive 1/2" gap at the front end of my hood. Is there any way to raise up the front fascia to meet up with the hood any? I have already bottomed out the latch mechanism on its mount. I lowered the rubber hood stops to their lower limit.I trimmed off the front of the hood already too. The sides line up nicely and the rear corners meet up well with the fenders, i just have this huge gap at the front..... HELP its ugly.
Old Apr 21, 2006 | 02:23 PM
Gr89RS's Avatar
Car: '02 Z06
Seems like everyone with the 4" cowl has that problem, I think its more an issue of the quality in the make of the hood rather than an alignment issue.
Old Apr 21, 2006 | 06:27 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Shoulda bought a glastek. Really no way to fix that.
Old Apr 21, 2006 | 06:40 PM
Raiderfan's Avatar
Car: '92
Caulk it..........
j/k
Old Apr 21, 2006 | 11:10 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
Try cutting a coil off the bottom of the hood spring. It should bring the hood about an 1/8th in. closer to the bumper cover. Good luck with it, Josh.
Old Apr 22, 2006 | 09:07 AM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
I don't even have the hood spring installed right now, but i can tell that i will need to do that mod anyway.
Old Apr 24, 2006 | 12:41 AM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
what hoodspring?
2 things:
1. Loosen a few bolts on the nose of the car and then u can get someone to lift it up while u re tighten the bolts.. i got a good 1/2 at least out of this
2. everything is ajustable on the F-bodies, almost. loosen the bolts on the hood that attach it to the struts and pull the hood forward
Old Apr 24, 2006 | 09:08 AM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Thanks now i have a few different routes. Last night i actually started elongating the latch mechanism holes, that is working out a little bit of it.
Old Apr 24, 2006 | 10:35 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I was in a slight front end collision and replaced the front fascia with an aftermarket fascia (bad idea). Fitment problems everywhere. And when it finally got together, there was a gap between the top of the fascia and the hood that made it look like the hood was always popped. I got sick of it, so I unscrewed the 9 or so screws at the top of the fascia, where the hood latch is, and shimmed it up about 1 inch all around. And by shims, I mean poker chips . I want to get some rubber grommets to put around the screws, to make it look more professional, but poker chips were around and they were perfect for adjusting the hieght a fraction all around.
Attatched pic: Left is front fascias with the gap, the right is the front after my pokerchip fix.
Old Apr 24, 2006 | 04:15 PM
Raiderfan's Avatar
Car: '92
Hey whatever works , plus that reminds me of the time I shimed my storm door with paint sticks.............
Old Apr 24, 2006 | 05:29 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
I recently tryed that with big washers under the bolts.. works for firebird too... my bumper support peice is mangled so its a crummy fix but it works
Old Apr 25, 2006 | 08:23 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Thanks for all the help guys
Old Apr 26, 2006 | 10:25 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
You have to pay attention on the notes for those Harwood hoods... they tell you that some trimming may be required. Most people have to trim the side edges of the hood so it closes all the way... and I think there is aliitle overlay in the front as well...
Old Apr 26, 2006 | 11:07 AM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Yeah there is a good bit of overlay in the front but i already trimmed it down, i haven't even cut down the sides yet. I hope that isn't my problem all along.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
