quick trim question
Old Apr 24, 2006 | 11:17 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
quick trim question
Im removing the trim on the bottom of the door. I know its riveted to the bottom of the door..are there any other rivets?..or is that it and its just like glued to the door with that adhesive crap?
Old Apr 24, 2006 | 12:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
it's neither glued nor riveted. The ground effects piece has 5 or 6 threaded studs that go through holes in the door, and hold on with speed nuts (tin nuts) from inside the door.
Look in your door, and at the edges you'll see a rounded-over acorn nut right along the edge of the door skin in the front, and another in the back. I believe these will be 12mm or 13mm nuts. Then after you take off the door panel, you'll find 3 or 4 more that you need to access with an extention through the specific inner door openings. These I believe are 11mm nuts. Take off all 5 or 6 and the piece will come right off the door.
Old Apr 24, 2006 | 09:07 PM
Car: 1991 Z28
Engine: SBC
what bout the rivets on the bottom of the door..i believe there are like 6- 8 of them...i know they are a part of the trim piece...they hold it from the bottom..
Old Apr 25, 2006 | 10:32 AM
Jim85IROC's Avatar
Uh, no. If yours has rivets, then it's because somebody decided to butcher your car.
The only thing that should be holding that piece on to your door is the 5 nuts.
In this pic you can see at the extreme edges of the door are the two black nuts that I referred to before, and in the inner door area, you can see 3 round access holes to get to the remaining 3 nuts. That's all that holds the panel on.
Perhaps the 91-92 door pieces are held on in a drastically different manner? What year is your car?
Old Apr 25, 2006 | 12:19 PM
Car: 1991 Z28
Engine: SBC
yea its a 92 and no its deff not butchered...deff looks factory. ill go get a pic..
ah wait wait i see whats going on here...those rivets hold the plastice ground effect onto the BRACKET that bolts to the door...so yea i just gotta remove the nuts then and then bracket and ground effects shoud..fall off heh
Last edited by LoudmouthSS; Apr 25, 2006 at 12:23 PM. Reason: Automerged Doublepost
Old Apr 25, 2006 | 12:42 PM
Car: 1991 Z28
Engine: SBC
ah crap...well i got the three inside the dorr...but it looks like the outer corners arent nuts...
Old Apr 25, 2006 | 01:32 PM
Jim85IROC's Avatar
on my ground effects, the studs went right into the fiberglass. There was no "bracket".
Old Apr 25, 2006 | 09:06 PM
Car: 1991 Z28
Engine: SBC
yea i got it off...it was mounted the way you guys were saying...but the plastic parts were riveted to a metal bracket that was then bolted to the door. Well anyway thanks for all the help guys
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
