88 Firebord Passenger headlight motor has no power..
Old May 7, 2006 | 10:28 PM
admrlam's Avatar
And i cant figure out why.
The motor is fine, if i use leads off the drivers side connector it works. So according to the Haynes manual, it gets power from *Fusible Link D*. Anyone know where it is? I havnt had a chance to get under the car to chase the wiring around...
Thats all i can think of, as everything else is working fine...
Old May 7, 2006 | 10:50 PM
michal_larson's Avatar
could da mota actually be bad? you do know if you had a camaro, none of this would be reality.
Old May 7, 2006 | 10:55 PM
admrlam's Avatar
The motors fine, i hooked up two leads to the connector for the other side, and the motor worked fine, 2 hours ago.
If i had a camaro, yes, it wouldnt be an issue. Good point, i guess ill.... um.... go sell my car and buy a camaro, to circumvent my headlight motor problem. Sweet.
Anyone else?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
