lexan or plexi back hatch
Car: 1984 Camaro Z28
Engine: 2000 LS1
Axle/Gears: Moser 12 bolt w/4.11's
are there any aftermarket back hatch options? we were stripping my 86 sport coupe down and that back hatch must weigh a ton!
there must be some lighter weight options out there.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I have yet to see one, but I am well aware that they weigh 100+ pounds. But you have to think of this...even though you will cut 50 or so lbs out of the rear, what will that do to your traction? I believe that the amount of weight pressing on the back of the car is a great contribution to proper weight transfer.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yep: Lexan windows are about $400. The notchbacks save some weight I believe as well. However, that's over your rear wheels so good luck getting traction on the street.
Engine: 2000 LS1
with a proper suspension setup, traction wont be a problem.
my friends with convertables have no problems with hooking.
and why would i need to dead hook on the street?
btw who sells these back hatches?
Car: 82z28
Engine: 406
Transmission: th350
Car: 86 T/A
Engine: HSR 355
Track = clean ground and you can use slicks- weight isn't as big of a deal.
Street = sand, rain, street tires. I've driven without a rear window, even with an auto, 2.77 gears, and a 305 I was spinning the tires trying to accellerate out of every corner.
My rear window with a rubber wrap around spoiler probably weighed close to 130 I'd estimate, so there's alot of weight to be saved there if you do it right.
Engine: 2000 LS1
Originally Posted by firebirdjosh
Well let's see,
if you have a properly set up suspension with decent tires, getting traction shouldnt be a problem. like any performance car traction is always an issue on street tires on the street.
but i see no need to "dead hook" on the street.
as i see it you have it backwards, the weight would matter more at the track then it would on the street.
Car: 86 T/A
Engine: HSR 355
Engine: 2000 LS1
how can you count rain and sand into this? no matter what youre driving they are going to be an issue, driving the way the car is now traction is hard to get in rain or sand, no matter how slow or fast i come out of a corner.
i dont see how they are relavent to this discussion.
your whole argument is how rain and sand will effect traction. well DUH it effects just about every cars traction.
i also dont see how you can compare the track to the street. the way a person drives at the track shouldnt be the way they drive on the street. and if you are driving your car like you are at the track then you deserve to wrap your car around a telephone pole.
driving around town with NORMAL road conditions i see no problem with removing 77lbs off the rear wheels. if your suspension is set up properly and you have compensated for the loss of weight there shouldnt be a problem.
at the track, traction is the name of the game, it can make or break. the ONLY problem i see with removing the weight from a traction stand point would be at the track, but even then with a properly set up suspension it shouldnt be a problem. for some its hard to get traction WITH the rear glass and full weight, but then again they should relook there suspension.
what about convertables? i havent seen many with abnormal traction problems that all the other fbodies dont already have.
Car: 91 Z-28
Transmission: 700R4, T-56 future
All he was simply saying is that you will be fine with less weight in the rear for the track unlike the street where the weight helps.
Car: '89 Firebird Formula
Engine: 305 TBI
well considering overall the convertibles weigh more, with the need for additional bracing, or power tops, etc etc... i doubt it would be considered an issue ;0
if your car is anything as stiff as mine is, which is awesome as hell when your flying through the twisties, but trying to start without spinning your tires even on dry pavement can be a chore.... i doubt youd be trying to lose 100lbs in the rear
this is why people would rather take there batteries and throw it in the rear to transfer 50 lbs
Engine: 2000 LS1
i dont know any with power tops. and that extra bracing isnt over the rear wheels.
infact i know one that is damn close to 3000# with driver. hooks just fine.
suspension. you guys dont seem to realize this.
Engine: 305 TBI
wasnt refering to thirdgens specifically, didnt get the impression you were either when you mentioned convertibles ;0
you well 50lbs missing weight in the back is quickly replaced by 100+lbs overall weight
if you really think weight balance doesnt play a role anywhere, then good luck
and keep your glass window around so when the plastic crap deteriorates alot like those wonderful factory lexan ttops, you will have something decent to put back on and make the car handle better again ;0
Car: 82z28
Engine: 406
Transmission: th350
That 50 lbs is 50lbs you have to have. So if it has to stay over the rear wheels is the best place for it...If they didnt need a battery i can garuntee theyd leave it out.
Car: '82 Bird S/E (sold)
Transmission: saginaw 4 speed
yes, harwood makes the rear glass, 332 from summit.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HRD%2D12921&N=4294908216+4294908198+4294925008+4294925242+4294838944+115&autoview=sku
Car: Pair of 92 Z28s
hey someone answered the question, how about that.
Thank you. I was curious also but it was looking like i wasnt gonna find an answer the way this argument was going.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well I would get a hood and the rear window. and setup the rest of the car as well. it wont matter so much if you remove weight from the front as well and use the correct shocks for transfer. after all once you bite the rest is lost in pushing dead weight
