Door hinge problem
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Door hinge problem
I was just about to start on rebuilding my hinges, and I noticed that the driver's side pin is messed up. I'm sorry for the bad picture, but it's the best I could do in low light. Does anyone know of GM still makes that pin and bushing, and what the part # is?
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am sure they do, you can also get them at your local auto parts store. Unless you're talking about the deterent roller them talk to Lonsal here on the boards.
Car: 1988 camaro conv.
Engine: 305tbi
Axle/Gears: dont know yet
door hinge pin and roller
THE PIN AND BUSHING FOR THE LOWERS IS STILL AVALIBLE FROM GM.LOOKS LIKE YOU NEED THE ROLLER PART#GM20058035,YOU NEED THE STUD THAT HOLDS THE ROLLER IN TO.STILL AVALIBLE FROM GM.IF THE UPPERS ARE FAIRLY TIGHT DONT MESS WITH THEM.
Car: '85 TA
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Good tech article here for sagging third gen doors: From HighPerformancePontiac.com. magazine.
Firebird First Aid, Part III -- High Performance Pontiac
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally Posted by Psycho_91Camaro
those springs are such bitch to put on.. I just left mine without it
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by firebirdjosh
Yeah, I had to do the same unfortunately.
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
the spring tool is only about 20.00 and available through any tool truck or paint and body supply house. only takes a couple minutes with correct tool. hawks has all the hinge parts nec to correctly repair sinking doors. including the redisigned heavy duty pins.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
