Tools needed?
Old May 18, 2006 | 09:33 PM
bbatton's Avatar
Car: 86 Camaro
Transmission: 5 speed
Tools needed?
I'am going to the J/Y saturday to get a driver's side door. I need to know what type of tools to bring with me to get the door off with?
Thanks.
Old May 18, 2006 | 09:41 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
some wire cutters and a socket set. if you dont need the glass than you bring a hammer
Old May 18, 2006 | 09:47 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I'd bring some combination wrenches and a breaker bar, too. The wrenches can get into tighter spaces than the sockets.
Old May 19, 2006 | 01:50 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
a swivel head ractchet makes things a lot easier also
Old May 19, 2006 | 03:40 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Don't forget something for that door spring.
Old May 19, 2006 | 04:30 PM
bbatton's Avatar
Car: 86 Camaro
How do I get the spring out?
Old May 19, 2006 | 09:26 PM
Car: 85 TA
you dont need to take the spring out to get the door off
take the hinges with the door.....they unbolt from the body...but if you must seperate the hinges lonsal(on here) sells a tool to take them out or you can use a big screwdriver...very dangerous....i tied a wire to mine before i did this so it would go flying and stood way back....also if you are going to seperate the hinges your gonna need a dremel or something to take the pins out.....
Dkelz313
Apr 7, 2016 10:38 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
