Quarter pannel tips please.
Old May 20, 2006 | 11:02 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Ok
I got my rear quarter panel and I am going to do it. I have been debating doing it for like two weeks now. But I have to do it. Any tips or tricks any one can give me. I have good metal fab and welding skills I have just never applied them to body work. Any tips would be great.
Old May 21, 2006 | 11:12 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
When you weld the sailpanel to the roof....just do seperate tack welds...waiting in between. If you just try to weld it up all together...the metal will get way to hot and will warp....creating alot more body work than needed. Make sure you grind down all the areas that are going to be welded.
Make sure to fit the panel several times before you make your first weld. You can actually screw the quarter on using self tapping screws and a drill to make sure you get the best fit possible. Make sure all of yoru gaps look good and that everything lines up.
Old May 21, 2006 | 09:06 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well I got started. I got the old one cut out and the new one almost all welded on. I am so far happy with how it is going. I am excited to be able to cut some of the rot out of the car by doing this. It looks alot better. Hopefully I will be done this week with it.
jrdturbo
Mar 31, 2016 02:58 PM
Gunner242
Dec 25, 2015 04:49 PM
Thaney9
Oct 15, 2015 06:37 AM
LC2 TECH
Oct 13, 2015 11:53 PM
jaridjohn
Oct 5, 2015 07:01 AM
