Paint my car with single stage
Old May 25, 2006 | 09:29 AM
MaineIrocer86's Avatar
Car: 1986 Z28
Hey guys,
I have a painting question for you...I am getting ready to paint my car and i am using single stage cause i cant aford to do a 3 stage paint job......I want to do a 2 tone paint sceme....but i am worried then when i remove the tape i will have a ride were the two paints meet....Is there anyway to use single stage and not have the line?
Old May 25, 2006 | 11:33 AM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
im not sure if there is a way to do it without making a ridge between the two paints because i painted my s10 black with red racing strips and the ridge was so distinct it looked like the stripes where a vinly or something. but i dont see how it would be possible unless you taped out your deisgn and then sprayed it, untape the design and then tape over the paint you just sprayed and then spray your design. but i dunno, im sure somebody here will be of better help
Old May 25, 2006 | 12:15 PM
Car: 1986 Z28
thanks, yes please if anyone has any insight into this it would be great!
Old May 25, 2006 | 07:44 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
It will not be possible for you to eliminate the line on a single-stage job. It is quite hard to do in base-clear. It can be done, it just requires extra work. It is also quite a bit more tedious to do a two-tone on a single stage job. The paint on your first color will have to be completely dry, to enable you to tape over it. Which will take a couple days. This process is easier in basecoat, due to the quicker dry/tape times, and the fact that you are using thinner coats.
Old May 27, 2006 | 09:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
there's really no easy way around the getting rid of the ridge between the two colors but you could just buy one of those rools of vinyl pin stripes and cover it
Old May 31, 2006 | 06:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
89importeater is steering you in the right direction.
Paint color #1 in the areas you want only.
Then remask for color #2. And when you think you have enuff paint.......
keep painting! You are going to wet sand off a good layer of the paint.
After wet sanding you won’t have a ridge.
(It’s when you someone decides to stripe a car after
it’s painted that they can’t avoid a ridge.)
“If people drove any slower
they’d be going backwards.”
Old May 31, 2006 | 07:26 PM
Car: 1986 Z28
can u wet sand single stage paint?
Old May 31, 2006 | 07:30 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Yes - but if it is a metallic paint you might want to wait for more replies.
Old May 31, 2006 | 08:15 PM
Car: 1986 Z28
nope its just black and yellow
Old May 31, 2006 | 08:55 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
Nope not even close...How do you expect to keep a straight edge after wetsanding all the ridge off? It will not be done on a single stage job. period.
Yes, wetsand and wheel your heart out. Years ago, the best show jobs were actually single stage, wetsanded between coats, re-sprayed, again and again, and then final sand and buff to a glorious shine.
Old May 31, 2006 | 10:16 PM
Car: 1986 Z28
it was just a question....I think i am going to do the 2 tone and then have a pin stripe...I would like to do it the right way...but i am a family man and have a bundgit of almost nothing....Thanks to everyone!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
