Why won't the turn signals work
Old Jun 8, 2006 | 01:29 AM
MeanMachine1986's Avatar
Car: 86 firebird
Engine: 2.8l V6
Ok i finaly decided it is time to fix the turn signals on my firebird, i have had it for about a year, when i first got it the signals worked fine, then the started to act up. The best description i can give is when the signals are turned on either nothing will happen, or the signals will cause a weird buzzing sound from the dash and the lights will stop working, all the lights work and the signals won't work on either side of the car, has anyone had this problem, what could be causing it and how do i fix it.
Any help on this topic would be great, cuz everywhere i go they tell me to replace the flasher in the fuse box under the dash, done it and it didn't help.
Old Jun 8, 2006 | 01:36 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
any burnt out bulbs anywhere? otherwise i'd think it was the flasher as well, might have better luck on the electrical board.
Old Jun 8, 2006 | 01:40 AM
Car: 86 firebird
Engine: 2.8l V6
ya all the bulb work, the flasher it under the dash right?
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
