hatch will shut but no were near all the way
Old Jun 27, 2006 | 10:48 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well my hatch will never shut completely and this is gonna be a problem for me to pass inspection because my hatch has to completely shut for the 3rd brake light to come on. When i close it it locks but it doesnt shut all the way no were near were its suppose to come down to how can i fix this? I thought about the 1986-91 Deluxe Hatch Pull-Down Repair Kit for tds will this do the trick?
Old Jun 27, 2006 | 11:44 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Whether the deluxe hatch repair kit will solve the problem depends on what is wrong with yours. If yours it caused by a cracked hatch motor housing then yes. If you have a bad fuse, bad striker-sensing switch or bad reversing switch, then no. First thing to do is remove the hatch surround trim and investigate a few things. First check that you have power at the red with white stipe wire that is plugged into the blue wire. If not, then check the fuse. On Camaro it is the #3 fuse (top row, third column from the left). On Firebird it is an inline fuse adjacent to the fuse panel.
Lon
Old Jul 2, 2006 | 10:07 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
my hatch doesnt pull down but the 3rd brake light does come on... maybe your brake light is out? are you getting power there?
Old Jul 21, 2006 | 01:11 PM
knightrider2278's Avatar
Car: I have a 1987 firebird
Engine: it has a 7.5l 455 in it
Transmission: i have a turbo 400
Axle/Gears: im not sure their factory
by brake light comes on but my trunk wont shut all the way it locks but you can pull up and down on it someone told me it was that thing in the back that pulls your trunk down,they said that might be bad
Old Jul 21, 2006 | 01:55 PM
lonsal's Avatar
It sounds as if your motor housing is broken. The motor housing is the clear plastic part that the motor slips into. It also contains the gear nut. It is common for them to break where the 3 screws mount it to the frame of the pull-down unit due to someone slamming the hatch. I reinforce them with aluminum and epoxy in that area and sell it as TDS 103121, $42.50. Download the instructions for TDS 101170 from the lower right side of my site or download the tech article I wrote from Thirdgen.org so you'll know how to properly disassemble it without breaking it.
Lon Salgren
Top-Down Solutions
Old Jul 21, 2006 | 02:44 PM
redfirebirdman8's Avatar
Car: '89 Trans Am
Engine: 305 T.P.I.
Axle/Gears: 10 bolt 3.73’s
you could try to move the motor up a few pegs and maybe it would catch, cause its on like a slide track
Old Jul 21, 2006 | 08:09 PM
glock22's Avatar
i have that same problem. iwas about to say screw it and just buy the whole housing assembly brand new
Old Jul 21, 2006 | 08:10 PM
glock22's Avatar
oops double post
Old Jul 21, 2006 | 08:34 PM
i didnt know you could move it up lol ill try it once i get it back together and can get a battery in the car thanks for the tip
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
ironbmt
Sep 27, 2015 06:00 AM
