T-top headliner question
Old Jun 29, 2006 | 03:59 PM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
My headliner has finally given me enough trouble and I want to replace it. I found some covered ABS ones from Paddock, but it says covered without center consle. My car has the center consle, so I was wondering if I could make the ABS one work on my car with the consle or not (do I just poke holes in it)? Thanks in advance for any information.
P.S. go to The Paddock if you need to see what I am talking about.
Old Jun 29, 2006 | 09:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You should be able to order it with no holes cut, so that you can cut what you need for the console, and not have the normal dome light hole.
By the way, there's only one company making the ABS headliners, so shop around for the best price. You're getting the same headliner no matter who you buy it from.
Old Jun 29, 2006 | 11:27 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
I got mine from hawks works great and when I got it and it showed how and were to cut it if you have the center consil and such it should not be to hard if you know what you are doing here is where I got mine from... Hawks Third Gen Parts-82-02 Camaro and Firebird Parts - Camaro or Firebird 82-92 ABS Headliner T-top or Hard top
but it is cheaper where your getting yours from ask if they could cut it out for you or somthing
Frozer!!!
Jan 19, 2024 04:55 PM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
