what do you recommend for new paint?
Old Jul 6, 2006 | 10:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
my friend and i are almost ready to spray the base and clear on his car. what do you recommend to do for wetsanding and buffing out the paintjob?
Old Jul 6, 2006 | 10:11 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I would recommend a good paint and body guy or a search in the forums!
Old Jul 7, 2006 | 06:42 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Search the body and interior forum. It's been brought up 101 times. And take it to a pro to get it buffed so you don't burn through the fresh paint (a lot easier to do than you might think).
Old Jul 7, 2006 | 07:56 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
I use 2500 to wetsand with then hit it one last time with 3000, make sure you use alot of water, go real slow and check your work often. If you cut through the clear coat you have to sand down and reclear, then I use some 3M polish to hand polish, make sure you tape all your edges and stay off the corners. Then use a good foam pad and watch your speed and the edges. It takes a while but be very patiant and you can get a good job out of it. Good Luck.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
carattini
Sep 10, 2015 07:46 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
