My car is solid!!!
Old Aug 3, 2006 | 01:02 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My car is solid!!!
besides for the burns. i guess I need a new sheild huh? what should I do to the area the is burned? Is it a threat?
Old Aug 3, 2006 | 05:06 PM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
Some of the body guys on here may have more input, but I think the burned spot will probably rust rapidly if you don't get it down to the metal and coat it with something.
Old Aug 3, 2006 | 05:49 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
ok, ok, so YOUR car is soild, gosh u dont have to rub it in like that
haha jk....1984 without rust, sweet deal man
Old Aug 3, 2006 | 06:48 PM
MavViper's Avatar
My 88 is like that too, floorpans and everything have no rust whatsoever. I'd post pics but don't wanna make you all jealous :P
Getting back on topic, you wanna get rid of that burn spot like theforce said. It'll probably rust quicker if left untreated.
Old Aug 3, 2006 | 06:52 PM
recaroguy's Avatar
Old Aug 3, 2006 | 08:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well yeah a cali car is gonna be solid, everyone knows that
but a NJ one no thats pretty uncommon
the burnt spot thats real bad, need to fix that ASAP dont let it get wet evne once or its gonna start rusting and it iwll get worse badly and in a HURRY
how in the hell did you burn the floor like that damn
thats crazy
thats a perfect body man, an 84 with no rust like that is RARE especially in our part of the country up here where you and i are
good luck
Old Aug 10, 2006 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have a 86 that lived in nj its whole life and is solid with no rust on the floors at all..
that burn mark is a little scary, maybe see if your cat or someting is touching the floor pan
Old Aug 10, 2006 | 07:57 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
same here its from ny got it when i lived there and its got 1 lil rust spot but will come out wit some sand paper and a grinder
Old Aug 10, 2006 | 08:03 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Could the burn spot be from an exhuast leak? Do you want me to sand under the car? Or in the car?
edit
I got the car for $450
Old Aug 11, 2006 | 01:57 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
i sanded the burn mark down, primed and then painted with my wheel paint because it matched the best
Old Aug 11, 2006 | 05:28 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Did anyone try to weld something to the underbody before you got it?
Because it had to be something very hot, and very direct to cause that.
*Edit*
Someone could have dropped a cigarette too. Is it burned on the bottom?
Old Aug 11, 2006 | 10:49 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Welp
I had an exhuast leak after the headers were installed. I took it to meinike and the welded the air tubes shut and a few other things.
Aparently it never was a smokers car, didnt smell like it either, but their was a cigarette under the carpet...
I dont smoke but I do
Old Aug 12, 2006 | 11:26 AM
Pocket's Avatar
Car: 91 Trans Am
Appears to be on the pass side directly under the seat
The cats there
Clogged/messed up cats will glow redhot and if the heatshield (not sure if older models even had one) aint there you will get quite a bit of heat bleedthru
Only other thing I can think of is a VERY sloppy weld job when a cat was replaced
Old Aug 14, 2006 | 09:13 PM
86 Tranni's Avatar
Car: 86 trans am
Engine: Lg4
lol wish my car was that solid
Reddeath210
Oct 6, 2015 08:20 AM
B_Dubya
Aug 26, 2015 05:09 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
