question about cowl hood
Old Sep 6, 2006 | 08:01 PM
IROC 89's Avatar
Car: 1989 iroc-z
i am in the market for a cowl hood and i would like to know what a cowl really does to help your car perform? does it help it vent heat better or what? lemme know!
Old Sep 6, 2006 | 08:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Its design is to draw in more air to help keep engine components cool and help with combustion.
Old Sep 6, 2006 | 08:14 PM
IROC 89's Avatar
Car: 1989 iroc-z
what will that really do for performance (sorry i dont know much about cars)
Old Sep 6, 2006 | 08:24 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well a cooler engine runs more efficiently, plus the hood look awsome. As far as performance, I dont know if it can actually be measured, but a fiberglass cowl is lighter than a steel hood.
Old Sep 6, 2006 | 08:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a cowl hood is designed to draw from a low pressure buildup at the base of the windshield on most if not all cars. air will actually flow into the cowl and onto the engine. i assume it could also help vent heat when standing still.
Old Sep 6, 2006 | 09:55 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Yeah right onto you window shield which is a bitch in the rain Fogorific.
Old Sep 6, 2006 | 10:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
removes 40 pounds off the front of the car and help vent heat/suck in colder air.
Old Sep 7, 2006 | 12:22 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Exactly what xpendable siad. Lets out hot air while letting cool air in. And yes when the temp is just right or in the rain that hot air coming out likes to make fog on the bottom of your windhield lol. Had that problem too on my bird
Old Sep 7, 2006 | 01:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In theory? Everything these guys said. In reality? Not much. Underhood temps might drop a couple degrees, but nothing you'll notice at the dragstrip or autocross. The lighter weight may translate into some minor handling benefits, but probably not much if that's the only weight saving you've done.
Now aluminum heads & a fiberglass cowl combined will save you nearly 100lbs, which is a heck of a good weight savings off the front of any car.
Old Sep 7, 2006 | 03:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Lets not forget about underhood clearance as a major benefit.
Old Sep 7, 2006 | 10:48 PM
84FirebirdChick's Avatar
Car: 00 F-bird/84 F-bird/88 Formula
Engine: 3.8L/2.8L/5.0L 305
i wouldnt have any other hood on my car my 2" cowl that i got from a junkyard earlier this summer has an interesting colour combo...VERY interesting...and it aint gonna stay lol. its like incandescent pearl, with dark purple fading to lighter purple with spikes coming up on the front part...ill take a pic tomorrow...
Old Sep 8, 2006 | 12:03 AM
IROC 89's Avatar
Car: 1989 iroc-z
the way i look at it...if im gonna spend that money...i wanna get at least a 4"...unless i find it in a junkyard...you lucky ****
Old Sep 8, 2006 | 12:09 AM
i hate anything bigger then a 2", anything larger then a 2" is just obnoxious to me. yea, they may perform better then my 2", funtion wise. I'm also 5'8" or so, and when im sitting in those seats, that you just sink into, like your in a cockpit, and with the long front end of these cars, i can barely see over the thing. if i had a 4", id need to sit on a phone book or 2 lol. also, anything larger then 2" is not street legal. i beleive it varies state to state, so youd have to check into that and keep that in mind.
Old Sep 8, 2006 | 01:19 AM
xpndbl3's Avatar
Car: 1984 Z28
but my motor won't fit under a 2" cowl. luckily i'm 6' tall so I don't need phone books.
Old Sep 8, 2006 | 11:27 AM
GhostDakota's Avatar
Car: 92 Dodge Dakota / 91 Jeep Cherokee
Engine: 5.9L / 4.0L
Transmission: A518 / NV3550
Axle/Gears: 8 1/4 w. 3.91's / D30&D44 w. 3.55
You mean this cowl hood? ;-)
I love you.. and uhm.. your... different.. hood :-D
Old Sep 8, 2006 | 11:29 AM
Engine: 5.9L / 4.0L
Yah, I am 6'4" and I can see fine over her 2" cowl
Old Sep 8, 2006 | 03:03 PM
damnit rick, you didnt have to put pics up...stop stalking me and my posts!!! lol.
Old Sep 8, 2006 | 03:10 PM
Engine: 5.9L / 4.0L
I wish I were stalking you.. that'd be hot.. lol jk... I get bored at work sometimes and I saw a cowl post and was like ooooh.. THEN I saw your post fawker :-P
Old Sep 8, 2006 | 03:13 PM
yea ok, whatever...stalker. lol. i need to paint that stupid hood...im about to go get some spray paint and tag it up lol.
Old Sep 8, 2006 | 03:19 PM
Engine: 5.9L / 4.0L
Do you want me to stalk you? haha... I can try to arrange that but I would feel shady or weird or something lol...
****... **** it.. let's get some sand paper and black spray paint for fiberglass.. or even just spray right over what's on there now lol!
Old Sep 10, 2006 | 07:05 AM
Night rider327's Avatar
Car: 1988 Camaro
oh boy.. Let me try to set some of this info straight.... The real idea of a cowl hood is yes to draw in air from the base of the windsheild.
If you seal your air cleaner to the hood so your carb is only sucking in the outside air you will get a pretty good HP gain...
Air inlet temp is worth 1% power for every 10*
Do the math with me here... say it's 80* outside... 170* under the hood.. If you seal carb off so your only useing that 80* air thats a 90* drop in inlet temp..
Thats 9% gain in HP.. 300 HP mill now you got 327 hp so you picked up 27 HP.
Then theres the weight factor.. The weight savings aint alot but every little bit helps..
My stock camaro steel hood with hardware weighs 67 lbs
My harwood 4" cowl bolt on glass hood weighs 51 lbs and thats with 2 auto meter gauges placed in the cowl opening.
100 lbs of weight = 0.10 seconds in the 1/4 mile
Old Sep 10, 2006 | 07:28 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Corrrrrrrect, Nightrider. In the first gen camaros, at least the Z's, sealed air cleaners to the cowls were used and the cowl opening had a door that worked off a solenoid that was operated at WOT to open the door. I do not know why they quit using them, but this is the system I am eventually going to implement. The aesthetics are also a real plus.
Old Sep 10, 2006 | 09:40 AM
Car: 1988 Camaro
Hot92rs... Yep the 1st gen z28's was like that with the sealed to cowl breather/scoop, so was the 70/71 chevelle SS, a few of the corvettes, etc etc... Even the nascar race cars uses the same set up with an "air box" thats ducted to the car's cowl.
It's a very good idea and design thats simply, works, and has been proven many times over. (and maybe thats why GM stopped doing it.. We all know how they don't like to make stuff that works and is simple lol)
Old Sep 10, 2006 | 11:41 AM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
A cowl hood with a sealed air pan is usally worth 1-3mph at the drags on average.If you seal it the entire width of the scoop all the way to the wiper cowl hot air probably wont fog your window.
Old Sep 10, 2006 | 11:52 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
so these cowls perform way better than the ss hoods{ when functal} sry for bringing up the ss hood but since the cowl works....~idea~ has anyone made a cowl hood with like an ss hood on top? like so you have the cowl and on the front of it you have the ss scoop? ~ ok any one got pics from like the driver seat of there cowl hood ?
Street Lethal
Apr 30, 2019 12:14 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
