weight reductions?
Old Aug 22, 2006 | 01:48 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
weight reductions?
how much weight can you lose off an 86 t/a? they weigh, what 3100? how far can you get them down? 2900? 2800?
Old Aug 22, 2006 | 01:56 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
An 86 TA weighs a bit more than that. Usually a TA tips the scales somewhere between 3,300 and 3,500 lbs. It all depends on the vehicles options, drivetrain, and even the amount of gas in the tank contributes significantly to weight. You can get these cars pretty light but it all depends how bad You wanna gut the car.
Old Aug 22, 2006 | 04:38 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Hes right, gas does make a significant difference. A full 12 gallon tank has about 78lbs of gas in it, while a quarter full has a little under 20lbs IIRC. I actually have a question pretaining to this:
Is there any company that makes aluminum parts to replace the steel ones? Such as aluminum doors or an aluminum hatch (ever tried lifting it with the pneumatic lifters completely removed)?
Old Aug 22, 2006 | 06:21 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Ya man that thing is heavier than my mom! But I really dont know about there being direct fit hatch parts available.
Old Aug 22, 2006 | 06:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the hatch is so heavy because of the glass not the metal part...if you like and can find a notchback hatch, they are fiberglass
Old Aug 22, 2006 | 06:48 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
!a/c
!sound deadining
! rear seats
!headliner
!Passanger seat
!dash
!radio
!speakers
I can go on for ever
Old Aug 22, 2006 | 11:51 PM
Engine: 2002 Ls1
Transmission: t-56
every source i have found say that the 86 t/a is under 3200!! so maybe with a 300lbs driver i could see it up around 3500lbs
Old Aug 23, 2006 | 03:42 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
depends on how much drivability youre giving up.
on a full race car, gut the interior (all the panels, console, headliner, rear seats) fiberglass hood, aluminum trans and driveshaft, remove speakers, and take off the bumpers (not the covers, the bumpers themselves). but i DO NOT suggest taking off the bumpers unless it is ONLY a track car.
Old Aug 23, 2006 | 06:48 AM
ntomsheck's Avatar
Car: 1989 GTA
Ah yes, forgot how heavy the glass is.
Spare tire is a good 40-50lbs or so with all the equipment (jack, tire filler) so take that out before an organized race (but don't drive around without it). Another thing for weight reduction is to go on jenny creg
Old Aug 23, 2006 | 04:25 PM
purpleZ-28's Avatar
some people have replaced the rear glass with lightweight plexiglass. ive actually only seen one car like that.
Old Sep 10, 2006 | 07:35 AM
Night rider327's Avatar
Car: 1988 Camaro
It's gonna be heavier than what you read...
Here's some scaled weights from a cat cert scale on my and my dad's car.
My dad's car... 1982 firebird.. No driver, full tank 16 gal of fuel, jack and spare tire, All emissions items gone, sound padding gone, glass hood, alum intake, etc etc..
3240 lbs total.... 1820 lbs on front, 1420 lbs on rear..
My car.... 1988 camaro.. No driver, full 16 gal fuel, no jack or spare, all emissions gone, light weight speaker box carpet, no heavy padding, p/w, SFC, spohn LCA's, alum wheels, etc etc
3320 lbs total..... 1900 lbs front, 1420 lbs rear
Old Sep 10, 2006 | 11:57 AM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Im in the process of more weight reduction on my 85 fbird (drag only) With all steel body except for fiberglass hood,all original glass ,lightweight carpet 1 racing seat,all interior plastic dash door panels etc,bumpers removed,crash bars removed,all a/c heater sound deadener ect, cast iron head sbc th350 12 bolt 4 gallon cell full cage , coil over struts and tubular fnt control arms etc,etc, 2850lbs w/o driver.This time going with lexan windows except for hatch ,gutted doors , tubular kmember rack & pinion steering etc. Looking for 2550 w/o driver
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
gord327
Oct 3, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
