t-top trim peice is rusting, how do I remove it?
Old Sep 13, 2006 | 03:51 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
If you pop-off your t-tops you will see that trim peice on both sides, each held in by 3 screws. Do I have to remove the t-top weather stripping to get that peice out?
The reason why I ask is the metal on both sides is rusting and just looks gross. Is it 1-peice or 2 peices? And does GM still sell these peices?
Thanks.
Old Sep 13, 2006 | 04:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The center filler piece for the t-tops is one piece and is held in by 10 screws and some adhesive/sealer crap on it's underside.
4 are hidden under the weatherseal (see attached image). There is around a 94% chance you'll get the weatherseal off w/o damaging it.
Attached Thumbnails t-top trim peice is rusting, how do I remove it?-t-topfiller.gif
Old Sep 13, 2006 | 05:05 PM
Car: 1994 Trans Am
Good, I have a 3% margin of error then. Anything over 97% and I would've simply let it rot.
Old Sep 13, 2006 | 05:51 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
you might as well replace your weatherstripping...the piece is rusting for a reason. Water is getting trapped under the metal and rusting it. I've pulled these pieces off of junkyard cars and found water trapped under them, and it hadn't rained in like a week.
Old Sep 13, 2006 | 07:03 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Yeah, I picked up a mint rust-free one at a yard last week for $2...talk about a steal!
Old Sep 13, 2006 | 09:18 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
T-Top Bar
I have the same problem with my car and I just purchased the new metal piece. However, I am afraid to remove it because of potential rust underneath. Is it common to see rust under this bar?
Old Sep 13, 2006 | 09:51 PM
deadbird's Avatar
Engine: TPI 305/ v6
And the reason is due to the design. It's not the w'strip fault either.
If you look at the design, the t-bar filler/trim (or whatever you want to call it) is composed of more that one piece of metal and rivited together. Even though that is not the flaw, it helps with the decay.
No matter how well the seals work, where the tops tuck under the center bar (that shows on the topside), water will get underneath/down there and go... where ?
While the t-top seal is supposed to seal against this seepage... over time & the seals shrinking, fate happens.
This is where the C&C tops having a 'gutter' have a mild design advantage over OEM tops.
Just my opinoin though...
Old Sep 13, 2006 | 10:03 PM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
That's a good reason TO remove it. If you have the new piece, pull the old one off and make sure there isn't any rust. If there is, fix it before it rots out. You don't have to make it pretty since it is covered. I pulled one off of a parts car with so much rust on it that I thought for sure the car body would be rusty underneath, but all the goop they put on at the factory and the original paint protected it and it looked new, so you probably don't have anything to worry about.
Old Sep 14, 2006 | 12:10 AM
Car: 1994 Trans Am
Now what about that bar that the t-tops slide under. I dented it accidently trying to take the trim peice out. Is that part of the top of the car?
Old Sep 14, 2006 | 07:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Take another look at the pic that deadbird posted. It's all 1 piece.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
deracer
Apr 11, 2016 12:04 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
3rdgenparts
Aug 8, 2015 07:09 PM
