roll cages bolt in vs. weld in
Old Oct 12, 2006 | 03:05 PM
slowmaro13's Avatar
Car: 1992 comaro
hey i don't no if i'm in the right place or not?!? but i was wondering what the differences were between a weld in and a bolt in cage as far as strength and so and so i just bought a 8 pt weld in from jegs and my friend said that i should of just got a bolt in but i disigreed can anyone help back up my point?
Old Oct 12, 2006 | 06:08 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
what I was told is that a bolt in is primarily for looks and a weld-in is for strength of the structure. I've got a bolt in....because I bascially wanted it for looks...probably provides a little strength compared to a weld in.
Old Oct 12, 2006 | 07:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
weld it in and be prepared to climb over it all the time, for a car that sees mainly strip duty it's fine, but for a DD it will be taxing on you everytime you want to get out. Don't forget that you can hit your head, arms, etc on it in a crash with no helmet on as well. Also on these cars, weld-in is the way to go unless you're using that bolt in 4 point which is not NHRA approved
Old Oct 13, 2006 | 05:07 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i am getting the back half of the roll cage (not sure what point that is) just casue my friend rolled his and i seen what a rolled camaro looks like after it folds in on its self
mines a DD but ya know ya mess around with them and can get in a sticky position
Old Oct 13, 2006 | 08:17 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Not to hijack this thread, but would a bolt on be something I should concider for the convertible or just go with the weld in???
I just want the back part, and not the one that goes accross the door panels!
Old Oct 13, 2006 | 08:38 PM
xpndbl3's Avatar
Car: 1984 Z28
no point in installing a 4 point cage realistically, since it isn't NHRA approved. It won't add much strength either since it's not tying the front to the back like a 6 or 8 point
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
