Trans Am front on a Camaro?
Old Oct 21, 2006 | 03:00 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
will a trans am front(fenders hood bumper) end fit on a camaro?
Old Oct 21, 2006 | 03:18 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Not without ALOT of modifications. Do a search as the subject has been covered in-depth.
Old Oct 21, 2006 | 05:03 PM
Car: CAMARO RS
Do you no what the posts were called
Old Oct 21, 2006 | 05:08 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Try this page
https://www.thirdgen.org/forums/sear...earchid=323959
Old Oct 22, 2006 | 07:58 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
Um... here's your links results... dont think it will help much.
Old Oct 22, 2006 | 11:57 PM
Blackknight's Avatar
hehe blue shift I got red shift
Old Nov 1, 2006 | 07:24 PM
Car: CAMARO RS
The camaro is a89 and the trans am is an 84 i have the fenders on, the hood did not line up with the camaro hood latch what other things will need to be taken off the trans am besides the obvious like the bumper and what are the modification needed it seems to fit so far? thanks
Old Nov 1, 2006 | 08:00 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
i think it will look horrible (and it's been done), but that isn't what you asked so i'll answer your question from a technical standpoint. if you use the fenders, hood, front bumper, front impact bar and front plate that the hood latch mounts to... it will bolt up. The front subframe of the two cars are identical. you have to unbolt absolutely everything and you can swap from one style to the other. As for going to firebird headlights, you will need the entire headlight harness which is the smaller of the two connectors at the bulkhead (goes through the firewall next to the brake booster). I'm not sure if the camaro light switch would trip the relay for the firebird headlights, you will need to figure that part out. You will also need to deal with any ground effects mounting points that might be different (basically, you may have to drill new holes in the rear of the firebird fenders to mount your camaro ground effects to them. Also, the camaro intake that goes over the radiator will not work with the firebird front end, so you will need an air intake from a firebird or some other routing that won't interfere with the lower firebird hood. I think that covers everything, but there may be some other details you would need to iron out.
Old Nov 1, 2006 | 11:49 PM
Car: CAMARO RS
Thank you so far people have seemed to like the idea i am doing it to be differnt and i am getting both cars for next to nothing and i needed the front off the camaro for my main car that was wrecked but thank you for not telling me it was a stupid idea if any one eles nos any thing eles let me no
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
